Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices
Thread Tools Display Modes
Old 02-03-2022, 04:33 AM   #41
samstown
City & State: Near the alps
My Country: Switzerland
Line Voltage: 220 V
I'm a: Knowledge Seeker
Default Re: Acer - N19C2 - MB EH7LW - Sudden death
Bad luck.. this morning PC doesn't start anymore, no sign of life. I'll have to reopen it.
samstown is offline   Reply With Quote
Old 02-03-2022, 05:53 AM   #42
samstown
Line Voltage: 220 V
Looks like UQ2 explode...
Old 02-03-2022, 07:01 AM   #43
mon2
mon2's Avatar
City & State: Windsor, Ontario
My Country: Canada
Line Voltage: 110VAC
Crap. See attached for UQ2 datasheet. This is a load switch (solid state relay).
Remove the defective part and check the resistance to ground for the output rails @ pins 8 & 9 of this component.
Order a few of these for replacement and future use.
mon2 is offline   Reply With Quote
Old 02-03-2022, 07:36 AM   #44
samstown
Line Voltage: 220 V
Thank you, I'll check.
Old 02-04-2022, 05:04 AM   #45
samstown
Line Voltage: 220 V
This is UQ2... I see the little crack, so that's what I tought it's the source of problem now. What do you think ? I've put the pin in red, that's correct ?
I have 0V on Pin 1 and 2 and 0.25 on 8 and 9
Old 02-04-2022, 05:31 AM   #46
mon2
mon2's Avatar
My Country: Canada
Please see page #14 of the data sheet. Where you see the chipped area is pin #1.
That is, the ic is soldered upside down so from the shared pic, pin #1 is the very bottom right of the part.
This is the input voltage to the load switch.
Then top left are pins 8&9 = output of the load switch.
Remove all power and check the resistance to ground of pin #1.
Then check the resistance of pin #8.
Post the readings.
The issue maybe upstream since the input voltage is not correct.
Where is the voltage for this load switch created?
Also check and post the voltage on pin #3 of this part. This is the enable for the load switch.
Old 02-22-2022, 04:54 AM   #47
samstown
Line Voltage: 220 V
my apologize. I got sick and forgot to reply. I'll double check this week.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
