Old 04-25-2012, 03:57 AM   #41
synatrol
City & State: NSW
My Country: Australia
Default Re: Dell 3008wfp faulty power supply
I managed to disassemble my Dell 3008wfp. The power supply circuit looked in very good order with all nichicon (125 degree celcius) capacitors looking healthy. I'll need to invest in an ESR meter to check further.
For future reference these are the steps that I followed to disassemble this monitor:
1. Disconnected the monitor from mains and PC and relocate it to a very well lit area.
2. Using a credit card with one edge sharpened, part the top of the bezel from the black center plastic divider.
3. Using a plastic tire lever tool (ones for removing bicycle tires) wedge it into the gap made by the credit card and lever the tool so the black plastic center divider rises. Push down on the bezel and hopefully you have unlatched the clip. If you are seeing metal clips then you are removing the wrong clips. The clips are plastic and clip into the center black plastic divider (dividing back panel and the front bezel). Several tire levers help. Be careful around the bezel buttons as there is no slack for the ribbon cable.
4. With the bezel un-clipped rise the top of the bezel up by 90 degrees so the three very small screws holding the bezel button card can be removed. Remove the button card and from the bezel and put the bezel away.
5. Remove the monitor from the stand - 4 torque screws.
6. Place the monitor flat on a table with the screen up.
7. Un-clip the back panel with the center divider still attached from the metal body of the monitor. The tire levers or screw driver will do.
8. Turn the monitor over so you are now looking at the exposed metal body. Pull off all the metal tape that is in the way (pretty much all of it).
9. Disconnect the ribbon cable from the plug (pull out the brown ends by levering them outwards with a very small screw driver). Place the ribbon cable with buttons on the end in a safe place away from where you are working.
10. Remove the single screw holding down the card reader. Slide the card reader from the slots holding it place.
11. Go to the opposite side now and remove the two screws holding down the cover on this side. Lift the cover up and out of the way.
12. Disconnect the plug that is now in view.
13. Remove the three small screws holding down the top metal cover.
14. Slide the cover out and place it out of the way.
15. Remove all screws holding down the main electronics plate (6 of).
16. Remove the 2 screws securing the 3-pin power inlet connector.
17. Slide the main electrical plate towards the card reader and lift the top end up so it exposes two cables plugged into the back of the display.
18. Remove tape and unplug these two connectors so that the main panel can now be lifted away and worked upon. The power supply board can now be removed once the 4 screws on the back of the metal panel and all screws holding the power supply PCB in place are removed.
19. Good luck.
synatrol is offline   Reply With Quote
Old 05-04-2012, 11:29 PM   #42
synatrol
City & State: NSW
My problematic monitor is now working with no issues since I've connected my new desktop to it through the same video header (Display Port). Previously I was using a HP ProBook 6540b which at the time of purchase was one of few laptops with a DisplayPort. I bought this monitor 3 and half years ago in anticipation for a new desktop. I was getting worried that it wasn't going to last the wait of my new PC desktop. All happy days now. Is it possible that the laptop was driving the monitor to hard??
Old 05-06-2012, 05:43 AM   #43
r-sherwood
City & State: Nothingham
My Country: England
Thumbs up Re: Dell 3008wfp faulty power supply
Thank you, thank you, thank you very much - you guys are awesome!
My monitor died exactly one month after out of warranty, and also no help from Dell.
Awkward that DELL told me to throw this monitor away and doesn't not offer any repair service. I'll never buy any DELL products again!
It was not easy to disassemble the front bezel, hence I did some shots that may help other how I did it.
I've also some Schotkys (STPS40170CT) left (had to buy them in a package). If you're located in Germany PM me.
r-sherwood is offline   Reply With Quote
Old 05-08-2012, 04:25 AM   #44
synatrol
City & State: NSW
It's good to hear someone else has now managed to fix their 30" monitor. Definitely not cheap to replace in a hurry.
Sounds like D22 is a weak link in the design. Probably more and more 3008WDP owners will wake up to a heavy paper weight over the next year or so. Hopefully they'll find this thread also.
Old 05-08-2012, 07:55 PM   #45
sra15548
City & State: Brodhead, WI
My Country: United States
I want to thank everyone for their posts on the Dell 3008 monitor. I too have one of these at my job and it just died on me 2 days ago. Now I have some background to get it up and running. Thanks again for all the detective work!
sra15548 is offline   Reply With Quote
Old 05-19-2012, 12:22 PM   #46
gothery
City & State: Saxony
My Country: Germany
I managed to disassemble my broken 3008WFP today. Right now, I am stuck. I cannot find a way to remove the power board. It seems to be strongly glued to the metal back. Can anybody give me a hint?
@r-sherwood: I would be happy to take one of these.
gothery is offline   Reply With Quote
Old 05-19-2012, 12:34 PM   #47
jetadm123
City & State: California
Can you attach a photo of your board? It's hard to tell where you're at based on your wording.
jetadm123 is offline   Reply With Quote
Old 05-19-2012, 01:04 PM   #48
gothery
My Country: Germany
Here is a picture of the board. I removed all the skews. The heat sinks are tightly glued to the chassis.
My idea right now is to unsolder all parts from the heatsinks.
Old 05-19-2012, 01:24 PM   #49
selldoor
Slow Learner
selldoor's Avatar
City & State: Lancashire UK
These are the instructions - are there any screws through from the metal side as with the 3007? perhaps into the posts- pic of metal side please.
If it IS just stuck you will have to prise it off carefully.
1. Remove the plastic bezel around the LCD
2. Unscrew the three small screws holding the front panel button control circuit
3. Unscrew the right side and bottom screws that hold in the thin shiny metal covers
4. Unscrew the screw holding the card reader; disconnect the card reader ribbon cable.
5. Slide the cable reader up and out from the clip holding it in.
6. Unscrew all the visible screws from the metal cover that houses the circuitry
7. Unscrew the black screws on the top and bottom of the panel and slide out the metal brackets
8. Unplug the cable from the right side.
9. Slide the metal cover that houses the circuitry up a little bit and unplug the small ribbon cables
10. Flip the housing over.
11. Unscrew the circuit board screws and the screws by the power plug
12. Remove circuit board and unplug the three other cables
13. Replace and go backwards to reassemble.
selldoor is offline   Reply With Quote
Old 05-19-2012, 01:51 PM   #50
gothery
My Country: Germany
Finally, I managed to loosen the power board, with the right tool. Unfortunately I don't know the english name for it. See at the photo.
I took a series of photos of the disassembled dell 3008wfp. From the visuals I cannot see any flaw at all. On the metal covering the inverters, I found something that looks like rust.
My screen went dark one day and never turned back. Computers still recognized the display and it seems to operate except that it does not display any image.
Where should I continue to look or measure?
Last edited by gothery; 05-19-2012 at 02:54 PM.. Reason: Added more pictures with the heat-sink desoldered
Old 05-19-2012, 02:36 PM   #51
jetadm123
Have you tried checking D22 for a short yet? It seems to be a weak point for this power supply.
Old 05-19-2012, 03:28 PM   #52
selldoor
Slow Learner
selldoor's Avatar
I was going to post this earlier but saw the previous post and have been reading the thread so D22 is the priority check. Everything about it is earlier in the thread including its location
If English is not your first language and do not understand any of it just ask.
(Haha English is my only language and I barely understand it!!)
Paint Scraper- dont know about in the USA
When you switch on did the screen flash bright at all
What did the power led do - colour/ flash
Any sounds - hum pop hiss
The pictures are good but perhaps you can do better ones without flash?
I cant just see how it all fit together. is it the same as the 3007 in this http://www.youtube.com/watch?v=zKvAirYSqUM
Where does the power to the inverter board come from can you take the plastic off the inverter board and take a pic
of it.
We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
http://www.badcaps.net/forum/attachm...1&d=1290283049
http://www.badcaps.net/forum/attachm...7&d=1280167246
It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
Do you have a multimeter and soldering equipment & can you use them.
Old 05-19-2012, 05:14 PM   #53
gothery
My Country: Germany
I desoldered the D22 Diode and run a basic test with my multimeter. It seems to behave like expected. Blocking one direction and letting through the other.
@selldoor: I will try my best. I am from Germany. Right now it's very dark here.
I have a multimeter and basic soldering equipment. I have mainly soldered wires for cables and no detail knowledge of the circuits.
As of the error. It went dark, the other day. Somehow I could manage to get a stable picture back and it stayed that way for a while. After that I turn the display on and I get a second of an image and it went totally dark after that. After that I never got a flash of the display again.
Finally, I started to investigate the issue today and found this very helpful thread.
File Type: jpg 3008wfp_power_board_front_without_secondary_heatsink_and_diodes.jpg (1.37 MB, 149 views)
Old 05-19-2012, 07:35 PM   #54
retiredcaps
City & State: Canada
I call it a putty knife.
http://en.wikipedia.org/wiki/Putty_knife
I normally use butter knives to open the monitor. After opening about 30 of these, you get to be pretty good with minimal damage.
--- begin sig file ---
--- end sig file ---
Old 05-19-2012, 07:45 PM   #55
synatrol
City & State: NSW
If the diode has not failed open circuited (high current) then you probably won't see if the diode is failing short circuited with a multimeter. I am assuming previous failure of D22 on other monitors in this thread was a sort circuit at operation voltage without causing the diode to fail permanently in an open circuit state (both directions). Maybe the other members who have removed their faulty Schottky Diode can report on the state of the diode with a multimeter?
I'd would start by replacing D22. Did the power light at the front turn off or go from blue to orange?
Old 05-23-2012, 12:02 PM   #56
Navlead
City & State: NAS Lemoore, CA
Just had one of these take a dump in one of our simulators, information and pictures on here were dead on. Only 8 more to watch break and repair....
Navlead is offline   Reply With Quote
Old 05-23-2012, 03:14 PM   #57
selldoor
Slow Learner
selldoor's Avatar
OK - thanks for the pictures They are a little better but if you look at them and try and see what I am asking you to test you will see the problem.
Wait and see if you get any more info about the D22.
Easy things to test - On pic 1 in the middle of the board there is a fuse F1 - check with meter on ohms200 should be the same as touching the probes together.Report result.
Also on that board the top connector is twisted - is it attached ok?
Again on that board, with meter on 2000 ohms can you check each transformers secondary winding- that is the two pads on the white band the connectors are on. Please records results as
T1 xxxohms
T2 xxxohms and so on
The Yellow caps on that board ar Samyoung which do not have a great reputation.
On Pic No 3 top right corner there are 3 other white fuses F301 and F302 & F303 next to each other
on Pic 6 there are 3 fuses bottom right F1 F2 F3 not all populated? Also on this board there are components labelled FL1 to FL8 these are fusible links and blow just like fuses so they can be checked the same There may be more of these and more fuses I just cant see.
Finally I attach a pic with joints marked in red - Maybe just the photo but they look burnt - can you check them - may need resoldering.
Old 06-04-2012, 01:16 AM   #58
gothery
My Country: Germany
I got my Schottky Diode replacement last week and managed to solder it this weekend.
And it works!!!
I put my old 30" monitor on an full one day test run. I checked all the input connectors and so far everything seems to be working!
That's really rewarding! Soldered by my own hands.
Thanks for all your help.
Old 06-10-2012, 05:59 AM   #59
timo
City & State: australia
My Country: australia
I just wanted to profusely thank everyone in this thread.
After reading it I was able to successfully repair my 3008WFP.
My monitor failed to power on(no lights at all) about 4 months after the warranty period expired.
I replaced my D22 with a STPS40170CT from RS components. Got a pack of 5 for $23.76(AUD) delivered.
It is now fully operational and works great.
It certainly would not have been even remotely possible without this thread so I just wanted to thank everyone here for taking the time to share your knowledge. It really means a lot to me and also saved me $1400 odd replacement dollars.
Thanks!
timo is offline   Reply With Quote
Old 06-10-2012, 08:38 AM   #60
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
The success stories sure seem to be rolling in on this one lately. Glad to hear we could be of assistance.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
