Hp 850 g7 `endpoint security controller ' error ....
    hp 850 g7 bios password my device
    I disabled the password using rc unlocker
    but now i am getting this error :
    here is my original encrypted file :
    Re: 'Hp endpoint security controller ' error ....
    at 1st boot you have to enter bios setup - Security and restore security settings to factory defaults. put back original file, see if error goes away and then try again with unlocked file and restore security.
    all donations are welcome,
      Here's your Unlocked EC file, but I need your other chip to fix this End point problem. The chip could be 16MB or 32MB.
        that didn't work
          here it is
            here it is
            In the first boot go to bios menu and disable security options (Default).
              it does not work
                it does not work
                what you mean by doesn't work? no image, no power or password still there?
                Program back your backup file and see if the device works or not.
                  He has to program both chipsets with your files and after that power on laptop. if he programs one chipset and power on laptop it modifies the content of other chipset.
                    the computer is working. but I keep getting the error on startup
                      program both chipsets with files provided by hardware1 and at 1st boot press F10 to enter bios setup, go to Security and at bottom you have restore security to factory defaults.
                        I did exactly what you said, but the error does not go away
