Hello - I am working on a professional keyboard Korg PA800 this is the CPU board and I need a better understanding as to identifying the resistor array. the resistor array is the RA123 or 126, the resistance I am getting across the pins is 2.841,6.63,6.61,6.64,3.220 when I switch the leads around I get the reading at the same points of 3.231,6.63,6.61,6.64,2.826. My questions is two fold, first is the resistance out of tolerance , and it could be worse under load, and what would this resistor be called if I need to order another one? I know the marking 332 is a 3.3 Kohm but it is doubling after the first resistor.
I do have several of these resistors on the board, some read good ( around 3.3k Ohms) both way and others have similar reading to what I posted above.
The issue I am having is RAM memory causing sound distortion. Any help would be greatly appreciated. I do have the SM on the unit but it does not give out any details.
