Lenovo L570
    Lenovo L570
    Does anyone have a dump of the 16MB BIOS for an L570.
    Cheers
    Re: Lenovo L570
    This model bios are 8mb size. try and report
      Re: Lenovo L570
      Thanks for the help.
      The flash fails with
      Error Image Size (8388608 .B) doesn't match the flash chip's size (16777216 B)!
      It's a W25Q128.V
      I did back up what was on it and it's 16,384 in size.
        Re: Lenovo L570
        put the bios backup here
          Re: Lenovo L570
          Here it is.
            Re: Lenovo L570
            try...
              Re: Lenovo L570
              Another
                Re: Lenovo L570
                Originally posted by danieltoader69 View Post
                Another
                I have flashed the W25Q128FVSQ chip on my L570 with this image but when I turn on the laptop it still asks me to enter a password. What else should I do to access the BIOS setup?
                  Re: Lenovo L570
                  press enter or use autopatcher available on the forum
                    Re: Lenovo L570
                    Originally posted by peste View Post
                    try...
                    Works like a charm with i3-7100u.
                    No password. No delay.
                    Just reset laptop few times and it start to work.
                    Update to newest bios was also possible.
                      Re: Lenovo L570
                      Does anyone had problem with ethernet card after bios change?
                        Re: Lenovo L570
                        try...
                        Do you know how to change MAC adres in this bios to unlock ethernet card?
                          Re: Lenovo L570
                          I found how to repair BIOS to have working Ethernet card in this laptop model.
                          If anyone want just write.
                            Re: Lenovo L570
                            just write it here and share the fix with everyone
                              Re: Lenovo L570
                              pls
                                Re: Lenovo L570
                                try...
                                thanks its work
                                  Re: Lenovo L570
                                  I tried this solution, but didn't work every time:
                                  Here it is:
                                  Read your MAC from the sticker under 1st RAM module:
                                  This usually start from 9829A6, if so, then replace actually given MAC into yours:
                                  1). find in HxD editor a HEX value: 98 29 A6. Beggining is Intel marking and the other 3 rows are your final MAC
                                  2). Search for 39 00 38 00 32 00 39 00 41 00 36 00. Be carefull and replace only letters, as "." are some stragne type of dots "�"
                                  3). Look for 9A 29 A6 FF FE. If rest of MAC is same as in other points (from source BIOS), then change the end of MAC. don't know why instead of 98 there is 9A, but works.
                                    Re: Lenovo L570
                                    try...
                                    thankyou ok
                                      Re: Lenovo L570
                                      Hello, this bios work also with ethernet card but need to be clean me. Can someone clean me? Thank you.
                                        Re: Lenovo L570
                                        Serial number ?
                                        Become a Badcaps supporter
                                        Thanks to all supporters.
