acer nitro an515-43
    acer nitro an515-43
    i have a acer laptop with no screen. im using tl866 and this device cant read xmc qu64 bios chip. so i tryed with another 64fw bios chip with original site bios but not screen, maybe i edited wrong. anyway i need that bios anyone can help me about that? motherboard = ph50q la-j621p rev1.0
    Re: acer nitro an515-43
    Select MX25U6435F ,you can untick Check-ID ,its 1.8V isn`t it ? .Post your bios backup .
      old bios here thank you
        can you help me please
          here you go ,extracted from latest bios update + your DMI .
          D 2B0000 - 2B0FFF
            ty for bios but no screen. i think problem is not about to bios.
              D 2B0000 - 2B0FFF
              got same unit with no display problem but my EC file is at 1mb. i attached my backup. thanks.
                Its the VGA bios youve posted. It might help others anyway
                  thanks. you have a VGA bios for that?
                    no i don`t ,only what you posted.
                      Originally posted by anethra View Post
                      i have a acer laptop with no screen. Im using tl866 and this device cant read xmc qu64 bios chip. So i tryed with another 64fw bios chip with original site bios but not screen, maybe i edited wrong. Anyway i need that bios anyone can help me about that? Motherboard = ph50q la-j621p rev1.0
                      here my back up try
                        Originally posted by jimore View Post
                        here my back up try
                        my back up
                          Hi, I have a FH50Q LA-J621P Rev 1.0 motherboard.
                          When I turn on the laptop, looks fine , but no picture at all. I downloaded the bios bin and write in the bios chip(25lb64csig) but after I turn on only once give me the "ACER" logo but nothing else.
                            did you do a clear me , if not try or post your old dump
                              When I first read the chip, it was empty. I using a TL866II plus programmer, and xgpro program. I attached a BIOS, what I used.
                                so ,you don t have the original bios !! post your serial number
                                  Sn:nhq6neu00p952110873400
                                  And when I tried to write the chip if I check in( Verify after) I get this message, but without the verify, the program show the programming succesful.
                                    Try
                                      Not working.(Turning on but no picture), is it possible because of the programmer not verifying the writing and cause the problem? How can I solve that problem?
                                        Clean the solder from the pins using some flux and braid,and make sure the pins all line up in or on the socket or adapter.If you have a spring loaded adapter try pulling up at both sides with one hand and try programming again.If you still have the same errors then the chip is bad,replace with another.
