it randomly locks up during high access situations, its slow to boot,slow to access, and the and the reallocated sector count is through the roof as seen in the pic, so should i clone the disk or is it ok?
is this drive bad?
is this drive bad?
Follow the white rabbit.Tags: None
Re: is this drive bad?
double check that. make sure it's an actual value, use hdat2 or smartctl
If that is the actual value, you have a failing drive. I don't know how it managed to survive that long, backup data!!!
Once you back up data, then you can try cloning the disk, my guess is and I have done this before with a failing toshiba drive using clonezilla, that it will most likely throw device not ready or failed to read errors and won't be clone-able.
hd tune is good & free it scans your drive for bad sectors
http://www.hdtune.com/Last edited by 1supertech; 06-18-2013, 03:00 AM.
only 2 bad sectors so the drive is ok? also the uncorrectable error rate it through the roof at 1932752060422 errors as reported by smartctl, is that bad?
Originally posted by 1supertech View Posthd tune is good & free it scans your drive for bad sectors
http://www.hdtune.com/Last edited by goontron; 06-18-2013, 08:44 AM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
sounds like it might have a bad board/cacheCap Datasheet Depot: http://www.paullinebarger.net/DS/
all the bad sectors are in the swap partition so all the data is intact. i hopeLast edited by goontron; 06-18-2013, 07:34 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Reallocated + Pending sectors = "Bad" Sectors
0 = OK
1-10 = Keep an eye on it
11-50 = Don't use it for anything important (swap or whatever probably OK)
51+ = Back up IMMEDIATELY and do not use
(In my opinion, anyway)
Originally posted by goontron View Postit randomly locks up during high access situations
Originally posted by goontron View Postits slow to boot
Originally posted by goontron View Postslow to access
Originally posted by goontron View Postand the and the reallocated sector count is through the roof as seen in the pic
Originally posted by goontron View Postso should i clone the disk or clone the disk?Last edited by cheapie; 06-18-2013, 09:32 PM.
Originally posted by cheapie View PostReallocated + Pending sectors = "Bad" Sectors
0 = OK
Originally posted by cheapie View PostNot good.
Originally posted by cheapie View PostI would turn that drive into a speaker or something
Originally posted by cheapie View PostFTFY.Code:$ dpkg --get-selections > /ihopethisworks/software.list
heck it wasnt 5 minuts after i copied my homdir that i was getting a "drive inaccessible" error.
thanks everybody for your help you saved my but.Last edited by goontron; 06-19-2013, 01:10 AM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
