LA-9001p black screen
    Working on this mobo....Black screen
    Flashed bios, checked voltage on every coil all are OK
    checked Ram voltages 1.5v , vtt pin no.201 ok, Vtt_ref at pin 1 Okk, pin199 3.3v Okk pin no. 30 also ok
    What will be possible solutions?
    Re: LA-9001p black screen
    Plt_rst pin13 also present
      Check U5 RTD2132S . http://*******/viewtopic.php?f=58&t=72780
        Where u r measuring plt_rst?? On wifi mini connector?? If so its not pin13
          Plt_rst means if on pin 13 of the kbc there is 3.3v
            at pin no.13 KB9012 and it is present 3.3v
              Also checked U15 U53 U54 nd Q91 at page 34, these are all working good.
                Thanking you....for yr replies.
                  Check the JLVDS1 display connector
                  pin 1 + LEDVDD 19v
                  pin 7 DISPOFF # 3.3v
                  pin 8 INVT_PWM 3.3v
                    Is the mb with dedicated graphics?? Since you are getting PLt_RSt means almost everything is ok in power sequence. Perhaps cpu reset problem. Might be onboard amd processor is bad.
                      One more thing I missed to mention when I remove ram ram beep is coming
                        pin 1 + LEDVDD 19v
                        pin 8 INVT_PWM 3.3v
                        19v is okk
                        but pin 7 DISPOFF# - 0v
                        pin 8 INVT_PWM - 0.4V
                        this reading done without lvds cable inserted.
                        Nd one more thing i am also not getting +LCDVDD at Q71.
                          Ya, this mb is with dedicated graphic card.
                            I always stuck in this situation Onboard processor is bad is there any way to confirm directly I take many hours and at the end come to this stage.
                              Keep the LVDS connected .Did you check U5 ,the ******* post has a chart with the working voltage from a good board.
                                there will many mismatch of the voltage of o/p RTD3132s as suggested by ******* that means it may be faulty...but i don't have same working IC.
                                  19v is okk
                                  You have to make the measurements with the lvds cable connected.
                                    Lcd power circuit
                                    3 volts not 19v I was wrong
