Where to get microwave plate rollers with tiny wheels (Panasonic…) cheaply?
    I've got several microwave's of different brands (incl. no-name ones) which are working just fine, have been cleaned and I have the right plates for them (or know which to get) but I cannot find the rollers. These are the ones which use very low rollers with tiny wheels (the ordinary ones are too tall and the glass plate does not have contact with that plastic rotary thing using them).
    I wonder where to get these? I found that for example Panasonic uses such, but the originals cost arm and leg, pretty much between half to full price of a new oven. This is insane.
    ADD// I've checked ali as well and unlike on fleebay, there seem to be some smaller (6.9"/17.5cm) cheap (a buck and some cents a piece) rollers with small wheels, I've asked one of the sellers for the wheel diameter so we'll see if I get any usable informatin; but for the price maybe it's worth just buying it and trying
    Re: Where to get microwave plate rollers with tiny wheels (Panasonic…) cheaply?
    step1: find the exact model that uses the rollers you need.
    step2: find a sevice manual so you have the factory part number for them.
    step3: start checking white-goods spares suppliers for replacements.
      Try searching for Microwave oven roller ring
      https://www.ebay.com/itm/3-Sizes-Mic...-/182967357382
      https://www.aliexpress.com/w/wholesa...microwave.html
      https://www.aliexpress.com/item/3pcs...004440389.html
      I had lots of these mostly panasonics, but threw them out a few years ago
        Ive had luck with going to the metal yards and salvaging them from dead appliances.
        Follow the white rabbit.
          Found only with large wheels or very expensive at fleebay, ali seems to be slightly better but there is little info about wheel size.
          stj: good luck with all those decade old no-names, best I got is maybe Daewoo
            Panasonic nn-h664
            Wheel height (diameter) = 15mm
            Wheel width = 8 mm
            You still need to find the ring to attach the wheels to.
              Guess this could work. I'll buy a few of those at 1.1 USD, could not get cheaper than that. They'll fit where they'll fit…
                Damn, missed it…gotta wait for next discount trolol
