Old 03-31-2010, 08:29 AM   #1
Welchs101
City & State: Cary, NC
Line Voltage: 120V 60Hz
Default ACER AL2017.....not working...Led comes on....with-flashlight can see image
I have an ACER AL2017 a friend brought over for me to look at. I am hoping to fix this monitor so that i can fix another monitor that i have been working on for a long time. This monitor has a power supply board very similar to the westinghouse power supply board shown in this thread
http://www.badcaps.net/forum/showthr...3&page=1&pp=20
In this thread above caps, power-fets and fuse were replaced. I did the same.
When i power on the monitor the lamps DO NOT COME ON.
The green LED light does come on.
Also, using a flashlight directed towards the screen, i can see the image.
Its just that the lamps wont turn on.
Note: I have checked the LAMPS using another monitor and they work fine.
Sounds like an inverter problem but i am not sure how to isolat the problem.
Any ideas on what to measure to figure this one out?
Welchs101 is offline   Reply With Quote
Old 03-31-2010, 10:36 AM   #2
PlainBill
PlainBill's Avatar
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
Default Re: ACER AL2017.....not working...Led comes on....with-flashlight can see image
If memory serves, this board is notorious for shorted inverter transistors and a blown fuse. The fuse is a smt style on the back of the board - look for the M in the inverter area. Also, replace all electrolytic caps with the usual exception.
PlainBill
Old 03-31-2010, 10:41 AM   #3
Welchs101
Yep, i already replaced the inverter , fuse and a few caps.
Old 03-31-2010, 12:40 PM   #4
seanc
City & State: Cambridge, UK
I think that board looks pretty similar to a board I have in my Viewsonic VX2235M (or similar model)
seanc is offline   Reply With Quote
Old 03-31-2010, 02:51 PM   #5
Welchs101
ok. I looked up the model you suggested not much in the way of repair or troubleshooting info. But thanks.
Old 03-31-2010, 03:03 PM   #6
seanc
Oops, it's VX2235WM, here's a good thread for pictures: http://www.badcaps.net/forum/showthr...light=vx2235wm
Old 03-31-2010, 06:48 PM   #7
Welchs101
the original power mosfets that were in this board had shorts between two of the legs. The part number for the original power fets were "40T03GP". I read on the bad caps forum that an equivalent part to use for this was the following:
http://search.digikey.com/scripts/Dk...863-NTP45N06LG
The badcaps thread which mentioned this part equivalency is shown here:
http://www.badcaps.net/forum/showthread.php?p=81893
For this monitor i was asked to measure the resistance between the leads of the power fet:
PowerFet1:
Resistance between Pin1(Red probe) and Pin2(black probe):open....resistance too high to measure
Resistance between Pin1(black probe) and Pin2(red probe):1.488MegaOhm
Resistance between Pin1 (red probe) and Pin3 (black probe):open....resistance too high to measure
Resistance between Pin1 (black probe) and Pin3 (red probe):starts out at 3.4MegaOhms and keeps increasing
Resistance between Pin2 (red probe) and Pin3 (black probe):4.43 Meg ohms
Resistance between Pin2 (balck probe) and Pin3 (red probe):2.7Megaohms and increases
PowerFet2:
Resistance between Pin1(Red probe) and Pin2(black probe):starts at 3.7Megohm and increases
Resistance between Pin1(black probe) and Pin2(red probe):3.33MegaOhm
Resistance between Pin1 (red probe) and Pin3 (black probe):3.64megohms
Resistance between Pin1 (black probe) and Pin3 (red probe):3.1megohms
Resistance between Pin2 (red probe) and Pin3 (black probe):3.96megohms
Resistance between Pin2 (balck probe) and Pin3 (red probe):2.75Megaohms and increases
Resistance between Pin1 of fet1 and pin1 of fet2: 5.8megohms
Old 04-01-2010, 06:17 AM   #8
frankNstein
This looks like a DAC-19M005 board if it is check F200 and see if it is open again.
frankNstein is offline   Reply With Quote
Old 04-01-2010, 06:26 AM   #9
Welchs101
I already replaced the fuse 200. I replaced several caps and the power fets.
Current status of monitor:
Power LED light comes on. I can see the image on the screen with the help of a flashlight. I have also checked the ccfls........they appear to be good.
Old 04-01-2010, 08:16 AM   #10
frankNstein
The fuse is probably open again. I have one of these boards with the same problem.
Old 04-01-2010, 09:23 AM   #11
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
Things to check:
1. The fuse. If it is open, don't replace it yet. Instead use a #1157 bulb (automotive tail light).
2. The state of the BL_ON line. It should be close to 0 volts.
3. Is power getting to the inverter controller?
PlainBill
Old 04-04-2010, 10:39 AM   #12
Welchs101
I checked the fuse........IT IS OPEN!
I bought a bulb but i dont know if it has the same voltage and current rating. The one i have is a Sylvania #921 (12.8V, 17.9W). Would this work? If not i will buy the one you mentioned in your thread.
You said the state of the BL_one line should be 0V......where do i measure this?
Is power getting to inverter controller...........Is the inverter controller the BIT3713 device?
Old 04-04-2010, 06:44 PM   #13
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
That bulb will work, perhaps better than the one I suggested. Now the idea is to use that to replace the fuse (temporarily) while you figure out what is causing the fuse to blow.
PlainBill
Old 04-04-2010, 06:57 PM   #14
Welchs101
Any suggestions on how to figure out what is causing it to blow while the light is on? I mean what do i look for? Do i touch comonents to see which one is getting hot or do i try and measure voltages?
Old 04-05-2010, 05:39 AM   #15
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
I'd do the 'touch tests' first - CAREFULLY!!!
PlainBill
Old 04-07-2010, 04:22 PM   #16
frankNstein
Check Q202 and see if it is open.
Old 04-07-2010, 04:50 PM   #17
Welchs101
will do. Right now i am fighting a really big fire........my A/C is not working. Soon as i get it fixed.......i will get back on this monitor.
Thanks for all the suggestions!
Old 04-07-2010, 09:11 PM   #18
smason
smason's Avatar
City & State: Alberta
My Country: Canada
Line Voltage: 120VAC 61Hz
I'm a: Hobbyist Tech
A/C??? WTF? It's April! We're months away from A/C season.
smason is offline   Reply With Quote
Old 04-08-2010, 05:42 AM   #19
Welchs101
A/C working......at least for now. Guess what........the cause was a bad "start" capacitor.
Anyway, back to monitors.
I checked Q202........but to be honest i am not sure what this device is and what it should measure. I am enclosing a pic of this device (Q202) ........it has markings on it of "14".
I am hoping to try the "light bulb" test later today.
Old 04-08-2010, 07:31 AM   #20
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
Use the standard tests for a transistor. Label the leads - lower left '1', top center '2', lower right '3'. Measure resistance 1-2, 1-3, 2-3; all should read > 100 ohms.
Switch to the diode test range and do these tests. Black lead goes to the first terminal, red lead to the second. You should get a reading of about .5 volts on only two of the six tests. The others should read open.
1 2
1 3
2 3
2 1
3 1
3 2
PlainBill
