Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 01-04-2018, 07:00 AM   #1
evilkitty
evilkitty's Avatar
City & State: VA
Line Voltage: 120VAC 60Hz
Default Which series are the low ESR ones?
Only concerned with the good brands
Low ESR Cap List
  • Panasonic
    • FC
    • FK
    • FM
    • FR
    • FS
  • Nichicon
  • United Chemi-Con (UCC)
    • KYB
  • Rubycon
    • Z*
Last edited by evilkitty; 01-04-2018 at 07:55 AM.. Reason: Add now known ESR Cap Series to list
evilkitty is offline   Reply With Quote
Old 01-04-2018, 07:16 AM   #2
stj
stj's Avatar
City & State: Europe
Default Re: Which series are the low ESR ones?
panasonic would be FC,FK,FM,FR & FS
rubycon, anything beggining with Z and to a lesser extent, YXF & YXG series
i cant help with the others - i dont have the datasheets on the drive.
go look here:
http://www.paullinebarger.net/DS/
Old 01-04-2018, 07:56 AM   #3
evilkitty
evilkitty's Avatar
City & State: VA
thanks
Just edited 1st post to make it a list
and i forget about the 1.5hr edit limit, hopefully a mod can complete it after that time
Old 01-06-2018, 06:19 AM   #4
sam_sam_sam
City & State: Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
I would also add the following
“United Chemi-Con (UCC)
KYB”
KY
KZE
LXY
This is what I use most of the time what is above
I also use these as well
FC
FR
FM
PW
I will use all of the following brands
Panasonic (2)
United Chemi-Con (1)
Next are equal in how I use these two brands
I will use these two brands when repairing Servo Drive Power Supply Board if the manufacturer has used them on the board if I can find the UF value and voltage and Size Low ESR value
Nichicon
Rubycon
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is online now   Reply With Quote
Old 01-06-2018, 06:54 AM   #5
Stefan Payne
City & State: Northern Germany
My Country: Germany
Line Voltage: 230VAC/50Hz or 400VAC/3P/50Hz
Low ESR =/= Low Impedance
Sometimes you want the Low Impedance...
Stefan Payne is offline   Reply With Quote
Old 01-06-2018, 07:21 AM   #6
sam_sam_sam
That very true
Old 01-06-2018, 07:44 AM   #7
evilkitty
evilkitty's Avatar
City & State: VA
now i am confused
https://www.badcaps.net/forum/showthread.php?t=12836
on a side not anyone have a screencap of the board referenced in this post (picture looks to have been updated since then)
i can understand that they are not truly equal, but they appear to be close, under what scenario does one come without the other?
Old 01-06-2018, 09:58 AM   #8
sam_sam_sam
When I look for capacitors I look at ESR value and Low Impedance value but I would not look for lowest ESR resistance value i look for something in the middle of the values that are listed
That is why I use these series that I listed before and I have not really had any problems with doing it this way ( switching power supply’s)
KYB”
KY
KZE
LXY
Old 01-06-2018, 02:23 PM   #9
mariushm
City & State: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Lower impedance is pretty much Lower ESR
Search for "[manufacturer] capacitor chart" in Google
Ex
Panasonic : https://industrial.panasonic.com/cdb...E0000COL92.pdf
Rubycon : http://www.rubycon.co.jp/en/catalog/...RIES-CHART.pdf
Nichicon : http://nichicon-us.com/english/produ...ini/index.html (hit diagram search)
united chemi con : http://www.chemi-con.co.jp/e/catalog...001.pdf#page=2
mariushm is offline   Reply With Quote
Old 01-06-2018, 04:08 PM   #10
sam_sam_sam
Thank you for posting this this will help a lot
Last edited by Per Hansson; 01-07-2018 at 03:52 AM.. Reason: Removed quote of prior post
