does polarity matter on resistors or SMDs?
does polarity matter on SMDs or resistors?
Re: does polarity matter on SMDs or resistors?
"SMDs" means Surface Mount Devices. Resistors, single-winding inductors, ceramic caps and film caps have no polarity - through-hole or surface mount. Electrolytic caps, polymer caps, tantalum caps, diodes (all types), transistors, FETs and ICs have polarity - through-hole or surface mount.PeteS in CA
I thought only crap-caps were WMDs (Weapons of Motherboard Destruction).PeteS in CA
nope as above
the only reason you may want to put a resistor in in a particular direction is so you can read them all the same way, this really helps with colour coded non smd type ones
(like some 5 bands are hard enough to read when you got the right direction)
smd, smc are usually numerically coded but still a good idea to run them in the same direction so they read the same direction.
I thought only crap-caps were WMDs (Weapons of Motherboard Destruction).You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
