Lifebook E752 Bios password
This topic is closed.
    Re: Lifebook E752 Bios password
    I need help finding bios password:
    my code is: 0222-0697-0107-0325-1674-5043 NOT 0272-0516-4124-2352-6563-6851, sr for my mistake.
    model Fujitsu Lifebook A561/D
    thanks in advance
      Hello, the same problem here
      Hash code: 0286-0703-4058-4255-2411-2275
      Keyboard: QWERTY
      Model: U745
      Please help me, thanks a lot
        thanks in advance
        Try: 8i1x07i1
        HoulScream try: 4afhkeeg
          Keyboard: QWERTY
          Model: U745
          4afhkeeg
            need password pls
            code is 0222-4045-6005-4227-5422-0099
            got stuck of this. really appreciate your help.
            thanks
              Originally posted by sslow View Post
              need password pls
              thanks
              w414z9aa
                Hi, my code 0B3E-0697-0012-0526-9102-8643
                will appreciate your help
                thanks
                  thanks
                  0y1l61yg
                    Hi, my code 0222-0487-8163-0326-6186-1138
                    thanks
                      thanks
                      4250emiz
                        Hi. I have the same problem with my lifebook e752. The bios is locked. I need Lifebook e752 Bios dump too. its hash code is changed if I use 3 random passwords.
                        Last code is : 0222-3697-4036-2049-9583-6514
                        it is 6x4 i cannot get master key for it. I found many programs which are calculating 5x4 codes but they are not working for 6x4
                        thank you for your helps.
                          hi, do you also have a solution to a 6x4 hexadecimal code?
                          203c-d001-0000-001c-b03a-cdb6
                          thanks!
                            Can you please help me, I have this code for Fujitsu E752:
                            0222-0697-0025-3157-4922-0467
                            Thank you very much!
                              svr813qj
                                0235jru1
                                  Hy Pascal,
                                  I need a BIOS password for Laptop Fujitsu Lifebook S751
                                  Code generated is : 0222-4070-4045-2742-1211-9971
                                  Thanks a lot!!
                                    [QUOTE=urke1111;867116]Hy Pascal,
                                    Code generated is : 0222-4070-4061-3435-6032-0243
                                    Thanks a lot! .)
                                      SOS
                                      need some help on fujitsu u772
                                      code is 0222-0544-0073-3439-9051-2211
                                      thanks
                                        Originally posted by urke1111 View Post
                                        Hy Pascal,
                                        Thanks a lot!!
                                        g42onqq6
                                          [QUOTE=urke1111;867124]
                                          Hy Pascal,
                                          Thanks a lot! .)
                                          gsmlv9uy
