Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Old 05-20-2019, 04:12 AM   #21
stj
stj's Avatar
City & State: Europe
Default Re: Does flux expire ?? Flux discussion.
keep in mind most fluxes are based on Rosin and a carrier - that could include petroleum jelly or animal fat!!
Old 05-20-2019, 08:37 AM   #22
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Originally Posted by stj View Post
flux absorbs moisture, so lifespan depends on how you store it.
btw, i like this - try it.
https://www.aliexpress.com/item/UANM...864986454.html
I have this, and don't think it works that well. Comparing it to the flux that's inside Kester 44 solder, it doesn't help solders stick as well. I still use some anyway in hopes it helps a little, at the very least it does prevent additional oxidation as it coats the surface.
Is this fake cheap chinese clone flux?
eccerr0r is offline   Reply With Quote
Old 05-20-2019, 09:09 AM   #23
stj
stj's Avatar
that's strange, not only is it not translucent from what i can see, the inside of the tin is painted too.
my original stuff the inside of the tin is not painted.
also, your tin has 2 sizes printed on it????????
Old 05-20-2019, 10:23 AM   #24
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Yeah they painted the inside of the tin as well, an extra cost. And yes it's waxy and not translucent. It's very soft, softer than wax. And yes two sizes, I suspect that it depends on how much was put into the tin.
Very weird that they have the same typos, minus "made in china" and that one japanese character instead of the chinese character...
Sigh... more knock offs...
Old 05-20-2019, 11:31 AM   #25
Dannyx
CertifiedAxhole
Dannyx's Avatar
City & State: Constanta
My Country: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hardcore Geek
Seems to me there's two routes one can choose: Amtech or the others The other knock-offs all seem to be the same, or at least at the luck of the draw
Wattevah...
Dannyx is offline   Reply With Quote
Old 05-20-2019, 06:04 PM   #26
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
I have some ~30-odd year old rosin flux and some recently "expired" acid flux (for pipes) that I need to try, to see what age did to them...
Old 05-20-2019, 07:29 PM   #27
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Maybe they use the same lid for a shallow and a deep tin?
-David VanHorn
Agent24 is offline   Reply With Quote
Old 05-20-2019, 07:54 PM   #28
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
True, could be the same label used for more than one container too...
I never measured how much rosin is in this tin. Doing a back of envelope calculation, this tin couldn't hold more than 50g actually...
Speaking of rosin, where's a good cheap place to buy it locally... seems like you're forced to buy online and pay tariffs nowadays...
Old 05-21-2019, 02:26 AM   #29
stj
stj's Avatar
you mean pure hard rosin?
china sells it very cheap - i think they are the only people who even use it.
Old 05-21-2019, 04:11 AM   #30
Agent24
I see dead caps
Agent24's Avatar
I have a little box of that, it was a free gift from UTSource. I heard you're supposed to dissolve it in alcohol and then you can use it. I haven't tried yet. Maybe once my pork lard runs out I'll give it a go.
Old 05-21-2019, 06:00 AM   #31
stj
stj's Avatar
lol
i had one of those little boxes too - gave it to a friend.
it was a gift from an ali seller when i got some iron tips.
Old 05-21-2019, 08:00 AM   #32
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Yes supposedly rosin + isopropanol = usable as flux directly.
No local source, was thinking may have to try a music shop that sells violins to try, but chances are it's cheaper paying the tariff.
Old 05-21-2019, 11:06 AM   #33
Dannyx
CertifiedAxhole
Dannyx's Avatar
My Country: Romania
Isopropanol ? Doesn't evaporate almost instantly and much more so when exposed to heat ? I wouldn't think of it as being the base ingredient for homemade flux
Old 05-21-2019, 01:21 PM   #34
mariushm
City & State: Romania
Dannyx ... i buy my liquid flux from TME.eu, they distribute flux from a Polish company, AG Thermopasty
Flux TK-83Liquid, medium-active flux, type 1.1.2 / 3 A acc. to ISO 9454-1, which is an alcoholic solution of rosin with the addition of organic activators, max. soldering temperature 280șC. Solids content 24%. Ideally suited for manual tinning to restore solderability.
2$ 50ml : https://www.tme.eu/en/details/flux-t...mopasty/tk-83/
3.75$ 100ml: https://www.tme.eu/en/details/flux-t...mopasty/tk-83/
15$ 500ml : https://www.tme.eu/en/details/flux-t...mopasty/tk-83/
27$ 1000ml : https://www.tme.eu/en/details/flux-t...mopasty/tk-83/
Shipping is around 5-6$... or it used to be... i remember it was around 17 RON when I last ordered from them.
18$ 1 liter https://www.tme.eu/en/details/rf800_...ag-termopasty/
(but this one it's recommended to clean boards after use)
they also sell rosin granules for example, 5$ for 500g bag, 100% rosin... https://www.tme.eu/en/katalog/fluxes_100484/
And yes, isopropil alcohol is used in liquid fluxes. You can pound those rosin chunks into tiny granules and mix them with isopropyl alcohol (i forget the ratio now, the video below says between 20% and 80% something of weight is rosin, rest is alcohol) and leave the bottle closed for a day or so to have the contents mix well.Optionally shake from time to time.
Also optionally you can add a tiny amount of glycerin, less than 1% by weight, basically a drop or so in a 100ml bottle.
See https://youtu.be/iv_2ULCmA28
tip you can also check the MSDS notes for fluxes.
For example here's the MSDS for that TK 83 flux above: https://www.tme.eu/Document/63d8258d...TK%281L_EN.pdf
<85% isopropyl alcohol
20-25% rosin
<5% benzoic acid
<5% adipic acid
mariushm is offline   Reply With Quote
Old 05-21-2019, 02:50 PM   #35
stj
stj's Avatar
"diode gone wild" uses the solid rosin by dipping the iron in it and splashing it onto the joint!!!!
Old 05-21-2019, 04:06 PM   #36
mariushm
It's a bad technique but my father did it the same way... that's how he soldered stuff in the 1990's when I was a kid. Romania being an ex communist country, there was no access to more clever soldering stations, you had no choice but to use those 100w soldering irons.
Problem is he can't help it as long as he uses that soldering iron... it's a 100w iron which uses a shitty "transformer" that's not designed to run for more than 15-30s at a time and the copper wire at the tip heats fast.
So he gets a chunk of rosin on the tip and basically just hopes the copper wire cools enough before it gets burned by the iron tip (if the finger keeps pressing on the trigger)
Old 05-21-2019, 05:58 PM   #37
stj
stj's Avatar
it wouldnt be too hard to hook one of those guns to a reostat or lamp dimmer, motor speed controller etc.
Old 05-21-2019, 06:07 PM   #38
Agent24
I see dead caps
Agent24's Avatar
You'd need a motor controller wouldn't you? The inductive load of the transformer would be bad for a simple Triac dimmer?
Old 05-21-2019, 06:37 PM   #39
RJARRRPCGP
City & State: North Springfield, Vermont
Line Voltage: 123-127V 61.5-63.5 Hz
The second one on the left, looks like the inside of a bee hive, LOL!
(A.K.A. the "bee hive flux")
Asus P6T Deluxe
Core i7 Extreme "Bloomfield" 965
PNY GeForce GTX 960
Windows 7 SP1
SoundBlaster ZXR
Corsair TX850M PSU
"Don't eat yellow snow!" -Salem
RJARRRPCGP is offline   Reply With Quote
Old 05-22-2019, 12:25 AM   #40
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
How well does lard work?
I collected a bunch of tallow that I rendered before tossing a piece of food waste that I should try...but I suspect it has little cleaning activity... incidentally, I wonder if this foggy "flux" is animal fat plus a little rosin...
Badcaps.net Technical Forums © 2003 - 2019
