Vizio M50-D1 power supply dual voltage?
    Re: Vizio M50-D1 power supply dual voltage?
    I would lookup the spec sheet of the PFC IC to get more info about the PFC section.
    For example FAN7529_PFC, as you can see the VCC get the kickstart Voltage for the main rectifier via the resistor, that resistor has to be chosen correctly if it is made to run strictly at no higher than 140V or made to handle from 85 ~ 240VAC.
    So look up at the spec sheet of the PFC IC, that may give you a clue.
      i am now curious why someone stationed in DE got a chinese tv from the u.s. instead of a chinese tv from germany!
        GeorgeGadgets... Did you use a transformer or plug in with just an adapter? I'm in the same boat... Opened up the tv backing, and the board on my little vizio was clear about 110v - 240v rating, but my big vizio power board doesn't specifically list any input ranges.
        To the gurus... Image of power board is attached. Is this 220V compatible?
          Is there a sticker with the input voltage rating on the back of the tv?
            it looks like it would take it - atleast from the caps and movs
