Old 05-05-2019, 07:14 PM   #21
Brucetafer
City & State: Orlando Florida
Default Re: samsung un55f7100 clicking led flash
Let me know if you need anything else from me, Im trying my best but now the powers out, summertime started in florida
Brucetafer is offline   Reply With Quote
Old 05-05-2019, 10:02 PM   #22
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
There 5 left side LED strings and 5 Right side LED strings.
Each string has + and - label for each pin.
I.E.
L1 + , L1 -
L2 +, L2 -
R1+, R1-
R2+, R2-
on and on and on..........
So it should have 20 readings.
You reports do no make any sense to me:
L1 27.5v
l2 56.5
L3 56.5
L4 56.5
L5 27.5
R1 27.5
R2 56.5
R3 56.5
R4 56.5
R5 27.5
You also reported that the backlights are flashing them those numbers should be jumping around which is what we are trying to find out.
And since the power relay is clicking then I do not expect the Voltages from the power supply board to be steady either. For the relay to be clicking on and off I would expect either the standby power supply is not stable or the PS-ON from the main board is not stable, but you reported that all the Voltages checked OK which does not making any sense if the power relay is clicking on and off.
budm is online now   Reply With Quote
Old 05-05-2019, 10:15 PM   #23
Brucetafer
I.E.
L1 + , L1 -
L2 +, L2 -
R1+, R1-
R2+, R2-
L1 27.5v
l2 56.5
L3 56.5
L4 56.5
L5 27.5
R1 27.5
R2 56.5
R3 56.5
R4 56.5
R5 27.5
Sorry bud, Im sure this is annoying as hell for you, this isnt my field at all.. the numbers I posted are the LED tester voltage when running them induvidually, I havent been able to power on the unit since yesterday and our power just came back on..
https://www.amazon.com/0-320V-Output...79704832&psc=1
Im using on of these to test the strips and check for bad LEDS without taking the panel off..
Old 05-05-2019, 10:47 PM   #24
budm
budm's Avatar
You just have to have check all 10 LED strings by disconnecting the LED connectors from the power supply board and test each string.
I.E. Red probe to 1+, Black probe to 1- and record the Voltage readings as shown on the LED tester.
At this point we do not know if the power supply, main board, or the LED backlights are causing the power relay to click on/off or not, but I do expect the backlights to come on and stay on when the cable between the main board and the power supply is disconnected.
When the the cable between the main board and the power supply is disconnected I also expect the relay to come on and stay on and the DC Voltage measured between the two legs of the main filter caps (the two big lystics caps rated 450VDC laying on the sides) in the hot side to be about 380 ~ 400VDC if the board has pull-up resistors for the PS-ON and and the BL-ON pins.
At this point you also need to report the Voltage on the connector of the power supply that goes to the main board when the TV is working and when it is not working, there are labels for each pin so make sure to put down the pin name and follow by the reading for each pin so we can easily see what are missing.
Old 05-05-2019, 10:49 PM   #25
Brucetafer
OK i pulled the panel, any tips of how to test? they are the side emitting ones
Old 05-05-2019, 10:51 PM   #26
budm
budm's Avatar
Read post 24.
Old 05-05-2019, 10:56 PM   #27
Brucetafer
OK, I tested every single LED, and they are all working perfect, they all draw the same amps and volts.. I reset the 2 plugs on the leds just to make sure they arent the issue
Old 05-05-2019, 10:58 PM   #28
Brucetafer
Should I pull the caps and test them? Its gonna take me a solid hour or so to put the panel back in the housing
Old 05-05-2019, 11:10 PM   #29
budm
budm's Avatar
How do you read the amps when your LED tester does not have amp meter, it only has Volt meter to read the totla Vf of each LED string?
What are the Voltage reading for each string?
Old 05-05-2019, 11:29 PM   #30
Brucetafer
I have a bench power supply, the voltage readings for the strings with the led tester is
L1 27.5v
l2 56.5
L3 56.5
L4 56.5
L5 27.5
R1 27.5
R2 56.5
R3 56.5
R4 56.5
R5 27.5
do you want me to test each string with my bench supply?
Old 05-05-2019, 11:55 PM   #31
Brucetafer
so if i unplug the main board, the leds should light
im dumb, I thought if you unplug the power supply from everyhitn it should be in standby mode, mine is just clicking over and over..
Old 05-06-2019, 12:07 AM   #32
budm
budm's Avatar
Well that clicking of the relay has to be fixed first.
With the connector still unplug from the main board, you need to report the Voltage reading of each pin of the connector on the power supply board that goes to the main board.
Make sure to put down pin name and follow by the Voltage reading for each pin.
Most of the Samsung power supply board has pull-up resistors for performing self test when it is not connected to the main board.
BTW, what do the LED strips look like? I am trying to find out why LED L1, L5, R1, and R5 has Vf about half of the other LED strips.
Old 05-06-2019, 12:16 AM   #33
Brucetafer
All voltages are when its clicked on for that split second
1 11
2 12
3 11
4 1
5 1
6 1
7 1
8 1
9 0
10 1
11 11
12 1
13 12
14 12
15 10
16 1.2
17 12
18 0
19 0
20 0
21 5.3
22 5.3 constant
23 5.3
24 1 constant
Old 05-06-2019, 09:43 AM   #34
budm
budm's Avatar
I have no ideas what those pins are for to tell what the Voltage should be for each one of those pin since there are no pin names shown as instructed.
Old 05-06-2019, 11:15 AM   #35
Brucetafer
sorry the picture didnt upload..
1 B13v
2 Vamp
3 B13v
4 PWM5
5 OD_LE
6 PWM4
7 OD_ON
8 PWM3
9 GND
10 PWM2
11 B13v
12 PWM1
13 B13v
14 B13v
15 Vamp
16 BLU_ON
17 Vamp
18 GND
19 GND
20 GND
21 B5v
22 A5v
23 B5v
24 PS_ON
Old 05-06-2019, 11:19 AM   #36
budm
budm's Avatar
Please edit your post #33 and put the names on those pins, I am not going to look at the glared picture to figure out what each pin is and then write them down and post for others to see.
Old 05-06-2019, 04:04 PM   #37
Brucetafer
1 B13v 11
2 Vamp 12
3 B13v 11
4 PWM5 1
5 OD_LE 1
6 PWM4 1
7 OD_ON 1
8 PWM3 1
9 GND
10 PWM2 1
11 B13v 11
12 PWM1 1
13 B13v 12
14 B13v 12
15 Vamp 10
16 BLU_ON 1.2
17 Vamp 12
18 GND
19 GND
20 GND
21 B5v 5.3
22 A5v 5.3 constant
23 B5v 5.3
24 PS_ON 1 constant
Old 05-06-2019, 09:50 PM   #38
budm
budm's Avatar
1 B13v 11
2 Vamp 12
3 B13v 11
4 PWM5 1
5 OD_LE 1
6 PWM4 1
7 OD_ON 1
8 PWM3 1
9 GND
10 PWM2 1
11 B13v 11
12 PWM1 1
13 B13v 12
14 B13v 12
15 Vamp 10
16 BLU_ON 1.2
17 Vamp 12
18 GND
19 GND
20 GND
21 B5v 5.3
22 A5v 5.3 constant
23 B5v 5.3
24 PS_ON 1 constant
Thanks for putting down the pin names, it is so much easier to see what you have, the PS-ON is present so the switched B5V and switched B13V are on and running.
So those readings above are done without the cable going to the main board attached, corrected?
And is the relay still clicking at this state?
Old 05-06-2019, 11:00 PM   #39
Brucetafer
thats with nothing connected and clicking about once every 1.5-2 seconds.. its on for maybe 200ms then off for the rest..
Old 05-06-2019, 11:31 PM   #40
budm
budm's Avatar
Just to be sure, the clicking sound is from the black relay (with F3PA005V) printing on it, correct?
And you do have about 380 ~ 400VDC between the two legs of the main filter caps that I asked before in post #24.
