Go Back   Badcaps Forums > General Topics > General Computer Discussion
Old 04-10-2019, 05:23 AM   #3661
Dan81
SNES-powered
Dan81's Avatar
City & State: Romania
My Country: Bacau
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Re: Gateway Select 650 PC find
Originally Posted by momaka View Post
Got any Powork or PowMax PSUs in there?
Sounds like the gutless PSU thread may get an epic revival soon.
Nope.
Mostly Deer, Sun Pro, YX-GP (Delux branded), Yuelin, some noname OEM that uses a black PCB (yet the rest of it is worse than anorexic), KeyMouse, CWT ISO and finally an AT Macron from ~1995.
I guess I could post some of the crappy stuff when I have some time. There's a lot of them. There's also a sad 120mm PSU that has its wires cut - I think it might be one of the gutless Zumax but I don't really know.
Apart from that, I managed to save some for myself - a pretty nice Casecom (Sun Pro) unit, the Premier LC-8500BTX mentioned above, and a Frontier LC-8460BTX in which I swapped the guts from a G-Alantic (CWT ISO) unit that had a beaten case but the electronics were fine. I could post a picture of those that I fixed at this moment including that Frontier.
Main rig:
ASUS H61M-A
Core i3-3220 3.30GHz
MSI Twinfrozr GTX 750Ti 2GB GDDR5
6GB DDR3-1066
Samsung SH-224AB DVD-RW
Raidmax RX-500XT (recapped)
Seagate Barracuda ES.2 ST31000340NS 1TB
JNC RJA-52 case
Dan81 is offline   Reply With Quote
Old 04-10-2019, 09:38 PM   #3662
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Smile Gateway Select 650 continued (part 2)
Just sorted through the new pictures of the Gateway Select 650.
For those of you not familiar with the Kadoka motherboard, here’s a view or two:
And here is that interesting CPU VRM up close that I was talking about:
https://www.badcaps.net/forum/attach...1&d=1554953251
As mentioned, there are no electrolytic capacitors here or anywhere else on the motherboard – just Tantalum caps and ceramic ones. CPU VRM is 4-phase, high-speed switching, and with soldered heatsinks close to the MOSFET’s Drain tabs – now *that* is a GOOD cooling design.
Next, chipset and LPC SIO:
The whole motherboard cleaned up very easily as it wasn’t that dusty. Shame about the broken PCI slot, though. Speaking of which, I just couldn’t leave it there like that, so I removed it:
I suppose loosing one PCI slot is not going to be a big deal, as this mobo had five total before. Four should still be enough for everything I need (audio, LAN, maybe USB2.0… we will see. ) Of course, I do also have a broken (literally, snapped in half) Dell OptiPlex GX260 motherboard that I can pull another PCI slot from. But on that note, does anyone have any tips how to remove slots easily and without damage? I removed the above slot on the Kadoka with my 40W Radio Shack bulb desoldering iron. It was OK on the data lines but struggled on a few of the ground and power lines. Thus, I ended up melting a big ball of solder on one side of the slot pins where that happened in hopes of pulling the slot when I melted the entire solder ball. Unfortunately, that didn’t work so well. The solder fell through the vias instead, cooled, and then made it even harder to try to desolder. So that’s why you can see the pins on the actual connector are pulled out on one side. Does anyone reckon if hot air / a massive bottom heater will work (without melting the slot)? I might try that with the broken OptiPlex GX260 mobo. I also would like to pull the AGP slot out of that one to try putting it on another Dell board that has the holes for it, but no slot… though, that’s for another silly rainy day project.
Anyways, moving on… here is the bare case after I cleaned it:
Finally a case that isn’t rusty! It wasn’t very dusty either. Nice heavy steel too, just the way I like it.
Also, let’s not forget the manufacturing / model sticker:
Made in April 14 of 2000. Ha! Four more days before its 19th birthday!
All the parts that need to go back in the case:
https://www.badcaps.net/forum/attach...1&d=1554953575
But before that, I needed to fix a few things. First, the snapped supporting tabs on the top plastic piece:
PVC glue works great on ABS plastic! It just cures a bit too slow. It’s been over a week, and I can still leave an indent on the glue. In some cases, I’ve had it take almost a month to become fully hardened.
This is why I often use hot glue in places where it will work fine. Speaking of which…
Just before installing the motherboard in the case, I found that its 3rd USB port was broken and pins inside all mangled up. If it was a dual port, I could have tried replacing it with one from another motherboard. But because this was a single triple USB port, I just un-mangled the pins so that they are not shorting to each other (or the case) and filled it with hot glue. I suppose that is not that big of a loss either, as these are USB 1.1 ports.
After all of this, it was time to put everything back together – and so I did
A shot of the front:
I suppose the only eye-sore is that Philips CD-RW drive. For this reason, I actually removed it before storing the case. I will eventually fix that CD-RW drive too. (Already have glued the plastic bezel together and fixed the broken door mechanism. Now I just need to figure out why it doesn’t work at all – no power… but that’s work for a rainy day/weekend too. )
So, after all of this cleaning and fixing – THE PC WORKS! At first, the PSU fan was a bit grind-y – sounded like a bad bearing on a car alternator or water pump. But as it warmed up, it became quieter. Still, the PSU worked without problems. Voltages were rock stable and what they should be. Leave it to Astec to design a good PSU, of course. Almost all caps inside it are Nichicon. The original CD-ROM and floppy that came with the PC also worked – read through my Windows XP SP2 CD fine. The motherboard also Mem-tested successfully.
The only bits of original hardware that I haven’t tried yet are the LAN and sound card. I’m pretty sure the LAN card will work, as it was somewhat away from the motherboard carnage. But as for the sound card, we will see. That said, I did fix it up a bit, though:
The ports still need straightening (not really visible in the picture). But overall, it looks a lot better and actually can be installed in a slot again.
Oh, and I even managed to save the parallel IDE and floppy cables.
Before:
After:
On the IDE cable, I just cut the “ugly cut” it had. And for the floppy cable, I did the same and simply re-installed the end connector. I suppose that is one nice thing about parallel drive cables – they can be fixed (and shortened), if needed.
So there you go, folks – another old PC saved from the dump. I really have no idea what I will do with this one. But the plastics are in near mint condition – no yellowing and hardly any scratches on the outside. It looks many times better than my Select 750, which is all dinged up, a bit yellowed, and is even missing the plastic for the power button (to turn it on, I have to stick my finger in a hole on the front bezel to press the little button behind it ) Thus, at the very least, this could make a really decent-looking retro PC.
File Type: jpg Gateway Select - Kadoka motherboard (1).jpg (390.0 KB, 191 views)
File Type: jpg Gateway Select - Kadoka motherboard (3).JPG (340.8 KB, 189 views)
File Type: jpg Gateway Select - Kadoka motherboard (2).JPG (202.4 KB, 7 views)
File Type: jpg Gateway Select - Kadoka motherboard (4).JPG (86.4 KB, 5 views)
File Type: jpg Gateway Select - Kadoka motherboard PCI slot removed (1).JPG (166.6 KB, 9 views)
File Type: jpg Gateway Select - Kadoka motherboard PCI slot removed (3).JPG (40.6 KB, 4 views)
File Type: jpg Gateway Select - Kadoka motherboard PCI slot removed (4).JPG (43.8 KB, 8 views)
File Type: jpg Gateway Select 650 PC - bare case (1).jpg (109.2 KB, 4 views)
File Type: jpg Gateway Select 650 PC - bare case (2).jpg (67.7 KB, 3 views)
File Type: jpg Gateway Select 650 PC - bare case (3).JPG (104.7 KB, 3 views)
File Type: jpg Gateway Select 650 PC - bare case (4).JPG (40.3 KB, 192 views)
File Type: jpg Gateway Select 650 PC - repairs (2).JPG (33.1 KB, 4 views)
File Type: jpg Gateway Select 650 PC - repairs (1).jpg (57.6 KB, 3 views)
File Type: jpg Gateway Select 650 PC - assembled (2).JPG (140.2 KB, 190 views)
File Type: jpg Gateway Select 650 PC - assembled (1).jpg (78.1 KB, 193 views)
File Type: jpg Gateway Select 650 sound card - fixed v1.jpg (149.7 KB, 3 views)
File Type: jpg Gateway Select 650 PC - parallel cables (1).jpg (46.8 KB, 4 views)
File Type: jpg Gateway Select 650 PC - parallel cables (2).JPG (42.4 KB, 2 views)
Old 04-10-2019, 11:32 PM   #3663
stj
stj's Avatar
City & State: Europe
Default Re: best cheap/free scores 1.1
the eyesore is the windows sticker.
and stickers on light cases are bad anyway - when they eventually peel the case will be a different shade.
Old 04-11-2019, 01:44 PM   #3664
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 120VAC 60Hz
wow, someone did a number on that PCI slot! Very nice rebuild though. anything old & beige always has a place in my heart. Are you going to replace that PCI slot or just leave it vacant?
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 04-12-2019, 01:39 PM   #3665
Topcat
The Boss Stooge
Topcat's Avatar
today's scores were:
3x Dell 2010wb monitors, working
1x HP 1300n laser printer with ethernet print server module
a box of random whatnots (keyboards, mice, small routers, etc).
Old 04-13-2019, 01:47 PM   #3666
Curious.George
Tek TDS754D in good condition dropped off this morning. No probes (of course! :< ). These things have been falling out of the trees, lately (I think this is the fourth one I've received).
I'll check to make sure the attenuator board is intact and, if so, upgrade it (bandwidth plus "options") and give it a quick calibration before passing it off to the local "Maker" house.
Curious.George is offline   Reply With Quote
Old 04-14-2019, 02:00 AM   #3667
Dan81
SNES-powered
Dan81's Avatar
My Country: Bacau
Got a Seagate ST31276A 1.2GB and a HDMI cable for my PS3 for free.
Old 04-15-2019, 08:51 AM   #3668
mikay786
City & State: Leeds
My Country: UK
Got some really good deals of the last couple of weeks.
Yesterday
  • Macbook Pro Early 2015 i5 2.9Ghz / 8GB / 512GB SSD - £60
Backlite wasnt working, checked fuse which was good. But in the process of taking it apart and cleaning some connectors its all working it seems. Dont want to get too excited just yet as has only been an hour or so, will see over the next few days. Runied the pentolope screws whilst opening thinking they were star screws but cheap enough on ebay.
  • Mitutoyo 293 micrometer - £10
Super accurate and pricy, measure a piece of paper down to the micron. impressed
  • Xbox One console only - £20
Seems to be working fine
Last week
  • Got 2 x HP 8470P Laptop - i5 3320M / 4GB RAM / 120GB SSD - £10 each
Seller had 8 of these, kicking myself for not buying them all but was thinking i should limit risk. Even for parts would have been worth more. Anyhow had to order power supplies but both working fine.
Loads of other dtuff but the above were the standouts.
mikay786 is offline   Reply With Quote
Old 04-17-2019, 04:31 AM   #3669
Dan81
SNES-powered
Dan81's Avatar
My Country: Bacau
Bought a Core i3 3220 for $19. Was worth the upgrade from a Pentium G645.
Old 04-18-2019, 11:00 PM   #3670
Topcat
The Boss Stooge
Topcat's Avatar
I rescued another wayward soul BP6, not working & loaded with bad caps. Cheap ebay score. I'm getting quite a collection of BP6's.....one of these days I'll start cutting them loose....working ones fetch a good price.
Old 04-19-2019, 06:31 PM   #3671
brethin
City & State: Owensboro, KY.
neighborhood collection time coming App 26 and I have a high amount going out to the yard this year, hate to see it go to waste but need the room for our ailing mother-in-law.
brethin is offline   Reply With Quote
Old 04-19-2019, 06:52 PM   #3672
momaka
momaka's Avatar
My Country: U.S.A.
They have indeed.
Like I said, I don't know how one can do so much damage. PCI slots tend to be quite tough in my experience.
That being said, I think the VooDoo3 graphics card is very likely FUBAR. What I thought was a small scratch on one of the RAM chips is actually a crack, I think. The way I checked: I used a screw driver to scratch the RAM chip in a direction perpendicular to the scratch, and I kept "feeling" the scratch no matter how deeper I went. If that's the case... only remedy would be to find some old SDRAM sticks with 16 Mbit chips... which I have NONE at all. Might put a post up in the "looking to buy" forum when I get to it and confirm if that RAM chips is bad or not. If it is, it's going to be a RAM chip replacement job + who knows what else. But for a VooDoo3 card, I think it's worthwhile.
*sigh* monkey technicians at their finest.
Same here.
Some years back, I'd grunt when I saw beige cases, thinking "old and useless". But now that I've seen what modern PCs are built like, I never skip a chance to get any beige cases.
Will replace it if I can salvage one without damaging it. Already have a few donor boards too.
Over here, I just put stuff in front of the driveway with a "FREE" sign several days before trash collection accompanied with a Craigslist "curb alert" post. More often than not, almost anything I put gets taken within an hour or two.
That sounds like me collecting old AGP video cards, thinking I could fix them up nicely and sell them... but I usually end up hoarding them instead (or rather, put in some old PC, which is not such a bad thing either, I suppose. )
Nice. Finally onto a more modern rig, eh?
I wonder how that Core i3 stacks up against the older Core 2 Quad and Athlon II X4 CPUs, granted it's a dual core chip with HT (but with much more efficient/optimized performance per clock/core.)
I just ran a test the other day, and it seems that even mid-range Core 2 Duo CPUs are getting a bit outdated now to run YouTube @ 720p@60Hz - without a good GPU to off-load decoding, at least.
Old 04-21-2019, 07:56 AM   #3673
Dan81
SNES-powered
Dan81's Avatar
My Country: Bacau
Scored a satin blue PS2 model SCPH-50004 with a matching controller and a matching car for free from a friend.
Also scored a 4GB DDR3 stick (not working sadly ), and a DFI K6BV3+/66 that doesn't POST. Probably has something to do with the green TEAPO caps all over the board.
Old 04-21-2019, 03:21 PM   #3674
TechGeek
Computer Geek
TechGeek's Avatar
City & State: Texas
Line Voltage: 122.5VAC@60hZ/200A
I'm a: Hardcore Geek
Teapo = Cheapo
For computer parts, go to Newegg
OR
Amazon.
For electrical stuff(pushbuttons, capacitors, etc), use Digikey
OR
Mouser.
Windows 10!? Oh yeah, that sorry excuse of an operating system that spies on you 24/7/365!
Samsung = Seagate = Seatrash = Trashgate
Don't buy Seagate drives. Don't use Seagate drives. If you have any in service right now, make plans to replace them ASAP.
TVs repaired: Toshiba 32AV500U
Stereo Receivers brought back to life: 1(Fisher RS-1056)
Stereos/Stereo receivers to recap: Fisher RS-1056
TechGeek is offline   Reply With Quote
Old 04-21-2019, 09:24 PM   #3675
Dan81
SNES-powered
Dan81's Avatar
My Country: Bacau
Originally Posted by TechGeek View Post
Teapo = Cheapo
Yeah, figured that out a lot of times with MSI
Recapped it with 2007 datecode OSTs from a discarded ASRock board but still no dice. It still doesn't POST and it's emitting a high pitched squeal from the ATX plug (this has happened before I recapped the whole board as well).
I used a ceramic Pentium 166 non-MMX and even a 133, no POST or anything.
Old 04-22-2019, 07:03 AM   #3676
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
Last week I scored an FRP'd Samsung Tab E 8.0 for $30 from the Tennessee pawn shop.
Took a couple of days of fiddling with it to finally bypass the FRP lock... and since it's an ATT unit with a locked bootloader, no ROMs or Root. It did make a good easter gift for my parents though.
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 04-22-2019, 08:08 PM   #3677
Curious.George
Just about 1T of ECC DRAM sticks (16x32G, 64x4G, 16x8G). Time to take an inventory of currently installed memory to see which machines will benefit from this windfall...
And, another Smart-UPS with the inevitable bad batteries. But, I really had to WORK on this one!
[Cripes, you'd think they could sense when they're cooking the batteries like this and shutdown the charger!!!]
Old 04-22-2019, 10:35 PM   #3678
Topcat
The Boss Stooge
Topcat's Avatar
A wee bit melted!
Old 04-23-2019, 05:13 AM   #3679
TechGeek
Computer Geek
TechGeek's Avatar
City & State: Texas
bzzzzt
Old 04-24-2019, 09:14 AM   #3680
brethin
Neighborhood collection is the 27th so if anyone wants literally everything I have bring $500 and you take it all. I'd guess it's $5000 worth of stuff based on eBay prices at half of what it sells for. Most all working, some new in box lots of rare things. It might all fit in a long bed pickup truck, maybe. Ailing Mother in Law taking my computer room and I closed all my storage units. Time to let it all go. The reason I say $500 is I can get that just taking it to scrapyard. Let me know soon.
Badcaps.net Technical Forums © 2003 - 2019
