Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Soyo - Shuttle - Supermicro
Old 06-10-2016, 07:11 AM   #1
madscientist132
City & State: b.a
My Country: argentina
Arrow Confused with 22mf Caps on soyo sy-p4vgm
I was given a computer with this soyo motherboard. Although some cleaning here and there, it works nicely, but i did not trust the caps despite no bulging neither visible bad symptom.
As i'm used to do, i got new caps and replaced them one by one. Now, happens that this motherboard takes 4 caps od 22mf*25v, i could replace correctly 3 of them, but i actually seems i confused the other one by a 10mf or a 100mf, that's the reason i wish to ask if anyone could let me know the proper location of the 22mf caps as i actually i have to replace a mistakenly placed one by one of 22mf. At this point, i didn't yet solder them so i fixing this mistake means just taking the wrong one and placing the correct one wherever it has to be done..
madscientist132 is offline   Reply With Quote
Old 06-10-2016, 10:58 PM   #2
Sparkey55
City & State: OK
Default Re: Confused with 22mf Caps on soyo sy-p4vgm
You should post some photos of the motherboard in question.
What are the new caps?
There is more than four caps on that motherboard.
Do you mean 2200mf or 22mf caps?
Sparkey55 is offline   Reply With Quote
Old 06-11-2016, 08:17 AM   #3
madscientist132
City & State: b.a
Thank you very much.
I had solved the problem learning that i did not misplace the caps, actually when i soldered them a drop of soldering wire went beyond it's trace close to the 12v connector for the processor and that short circuited the board. now i'm running the computer without any issue so i believe i have no further problems to ask for help.
