Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools Display Modes
Old 05-16-2019, 09:26 PM   #1
groovyfingers
City & State: Yucca Valley
My Country: United States
I'm a: Knowledge Seeker
Default Westinghouse LCM-22w3
DA-19M009 power supply to an A220Z1-Z01-H-S6 video board. Dead before and after replacing power supply caps, no power light at all. Checked big cap and has 168v, pulled one leg of glass fuse to see if it would give me the power light operation it did not so put leg of fuse back. This info was gleaned from an old post here. Looking to see if I could use others information to repair my monitor. Another post asked for the resistance of F1 which was 0.3 ohms, U6 voltages on the three legs which read 0v, 1.7v, and 2.7v. Finally U7 voltages which read 0v, 1.4v, and 2.4v. Any suggestions on what to do to revive this would be appreciated.
groovyfingers is offline   Reply With Quote
Old 05-17-2019, 07:56 PM   #2
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: Westinghouse LCM-22w3
What voltages do you have on:
CE104 (should be +5v)
CE101 (should be +19v)
I believe U6 is a the 3.3v regulator (Panel_vcc), the input comes from the +5 volts from the power supply
R_J is offline   Reply With Quote
Old 05-18-2019, 07:18 PM   #3
groovyfingers
Didn't jump out on a Google search, can you tell me their location so I can test?
Old 05-18-2019, 08:01 PM   #4
R_J
City & State: ☻
My Country: Canada
Check on the plug between the power supply and the logic board, the voltages are marked. you should have 13.8v and 5v
The capacitors, CE10x are marked on the power supply board
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
