Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 05-22-2019, 06:28 AM   #1
reddsta87
City & State: aiken SC
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Knowledge Seeker
Default vending control board
Morning guys. I'm trying to find information about this control board for a wall mounted vending machine by slim line designs. I've tried asking the manufacturer but they want 600$ for a new one. They called it the LF-80 control board. I see similar looking boards on ebay but none just alike. I need some guidance on schematics, 1 to 1 replacements, part numbers, references, or any other info on locating a solution for getting this machine up and running. Thanks
reddsta87 is offline   Reply With Quote
Old 05-22-2019, 06:43 AM   #2
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: vending control board
so whats wrong with the machine?
got a few pics of the machine it runs?
stj is offline   Reply With Quote
Old 05-22-2019, 08:09 AM   #3
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
first off, i'd re-seat everything that is socketed. Why doesn't it run? Is there power going to the board, is there any voltage on these large caps?
CapLeaker is offline   Reply With Quote
Old 05-22-2019, 08:59 AM   #4
stj
stj's Avatar
i know these systems, they have a lot of diagnostic messages and are pretty simple.
top connector is the display & key matrix,
bottom connector is row/column drive for the vend-motors.
small upper-left connector is AC power - the rest are all for coin and bill handling.
Old 05-22-2019, 10:07 AM   #5
reddsta87
My Country: USA
Correct. I am getting around 12VAC from the transformers to the board but there is no display showing on the LCD at all. The large caps I recently replaced, but i think there is one smaller cap directly beside the AC input that I removed but have not replaced tho I do have it ready to install. There isn't anything on the board showing that caps positive polarity side like there usually is and I'm not sure at the moment if it is directly connected to the neutral or if there is a diode in the path or not. The fuse from the transformer was blown when I received it so there might have been a surge that fried something before the fuse blew. Do you know any voltages/signals I should be seeing when its hooked up that would help have a better understanding of what the signal should be doing as opposed to what it is? I'll get a picture of the whole unit when i get home but its just a generic looking vending machine.
Old 05-22-2019, 01:51 PM   #6
Curious.George
Quote:
If you know you have a transformer (i.e., AC) sourcing power to the board, you should be able to trace (visually) the flow through the input rectifier, bulk filter and regulator to see if you've even got "DC" supplied to the parts internal to the board.
If the fuse blew, it's likely something early in the power conditioning had a failure so the results should be pretty obvious (with a multimeter/'scope)
How far any such failure may have propagated into the board will depend on the nature of that failure...
Curious.George is offline   Reply With Quote
Old 05-22-2019, 05:05 PM   #7
Retro-Hipster
Tinkerer
Retro-Hipster's Avatar
City & State: Salt Lake City
My Country: United States
Something I would recommend would be to take a multimeter and see if the ground/positive are shorted. (You could probably check on either side of those big tank capacitors.) If it is shorted then that could mean that there is something like a shorted mosfet/transistor. (Or other sillicon part.) Fuses often blow because something "down stream" has gone short. I would probably also see if that Fet is shorted as a "first things to check" sort of process.
__________________
“Men always seem to think about their
past before they die, as though they were
frantically searching for proof that they
truly lived.”
– Jet (Cowboy Bebop) -
Retro-Hipster is offline   Reply With Quote
Old 05-22-2019, 05:34 PM   #8
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Please also provide good clear hi-res of the whole bottom side of the board and also the pictures of the transformer connected to the board.
__________________
budm is online now   Reply With Quote
Old 05-22-2019, 06:10 PM   #9
stj
stj's Avatar
pick a chip with known pinouts, like the 8pin 93c66 eeprom, and meter the power pins to check for 5v
Old 05-24-2019, 02:06 PM   #10
Retro-Hipster
Tinkerer
Did any of this Help? Sorry, I'm just curious how it's going!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
