Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > All Others Motherboards
Thread Tools Display Modes
Old 08-15-2015, 10:37 AM   #21
behnam92
City & State: tehran
My Country: iran
I'm a: Knowledge Seeker
Default Re: Siemens 840D PCU50 Industrial Computer
can you help me identify the component that i marked in the attachment?
i thought it's cap and i bought smd cap with 157 marking on it but it isnt work properly .
Last edited by Per Hansson; 03-09-2019 at 05:11 AM.. Reason: Offsite image uploaded
behnam92 is offline   Reply With Quote
Old 08-15-2015, 10:45 AM   #22
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
probably a diode, compare it to one of the others.
stj is offline   Reply With Quote
Old 08-15-2015, 11:39 AM   #23
behnam92
My Country: iran
Quote:
i compared it to the other ones , it doesnt act like a diode when i test it with multimeter it act more like a cap, i mean in diode testing mode i hear only small beep and then nothing in both ways ,
the marking on it is something like "150 j " .
Old 08-15-2015, 11:54 AM   #24
stj
stj's Avatar
well "157" would be 150uf - do you have a cap meter?
Old 08-15-2015, 12:12 PM   #25
behnam92
My Country: iran
no i dont have one , but as i said i about 150uf caps but with different voltage rating(16v) and it didnt work , when i put it's own cap i have 3.3v output but when i use the one that i bought the voltage gets to 1.3 and it's not stable ,do you think the difference in the voltage rating could cause this problem?
Old 08-15-2015, 02:03 PM   #26
stj
stj's Avatar
no.
if the original gives 3.3v then isnt that correct?
where does the input to this "part" come from?
if it's the transformer then it is a diode - probably a fast or schottky type.
if that is the case then your cap is passing current and would explain things - need someone like budm to chime in on this!
i'm a digital expert, not an analog guy!
Old 08-15-2015, 03:53 PM   #27
behnam92
My Country: iran
no.
yeah it's correct but i run it with just one of those caps or diods the other one that i showed in that picture was short circuited so i had to desolder it and even if it is working with just one of those i had to find a replacement .
Old 08-15-2015, 04:14 PM   #28
stj
stj's Avatar
o.k.
you have a set of 3, and a set of 2.
so i assume the psu has 2 output voltages.
what are the output voltages and currents?
Old 08-16-2015, 02:36 PM   #29
behnam92
My Country: iran
i think i found the problem about why my system isnt booting up , as i said before this power supply creates some kind of power good signal for starting up the system,i've showed this figure in the pic below that i crop from siemens manual.
so i realized when i connect my power supply to 24V input it make somethine like beep buzz sound and it's from trans and i checked my outputs with osilloscope and i saw a voltage ripple in sync with the buzzing sound on all the outputs ,so i think this ripple affecting this power good signal and cause my system not to boot up , any idea on how can fix i this ? please help me i dont have much time for repairing it .
Last edited by Per Hansson; 03-09-2019 at 05:12 AM.. Reason: Offsite images uploaded
Old 08-16-2015, 03:48 PM   #30
stj
stj's Avatar
so why does the input voltage fail?
also, the output that diode is related to, what voltage and current rating is it?
Old 08-16-2015, 10:23 PM   #31
behnam92
My Country: iran
no i didnt mean that the input gets fail, i meant when i connect the power supply to 24V ,the siemens power supply act like that so i have ripple on its outputs ,
Old 09-09-2015, 01:38 PM   #32
sammer003
City & State: Edmonton
My Country: Canada
Did you resolve your issue. I've got a similar issue, PC won't power on. Not sure if its the power supply or MB.
Could you let me know what your resolution was?
sammer003 is offline   Reply With Quote
Old 09-10-2015, 10:28 AM   #33
behnam92
My Country: iran
yeah i solved my problem recently ,
does your fans starts or your system is totally dead?
if the fans start and your system isnt booting up you have to check two things, first check the north bridge as other experts mentioned it in previous posts, you can try to apply pressure to it by your finger and then push the restart button to see if you have any output on your screen ,
if that's not the problem you have to check the signal good from the power supply by an osilloscope,
i fixed my problem by changing the ic on the power supply that was responsible for creating the power good signal ,
Old 02-01-2016, 11:52 PM   #34
yoganath
City & State: coimbatore
My Country: india
hello experts , hope it helps for my future problems
yoganath is offline   Reply With Quote
Old 04-23-2019, 11:29 PM   #35
Horst7000
City & State: Haag, Lower Austria
My Country: Austria
I have two motherboards with that northbridge issue. Would anybody have some of this bracket A5E01040392 left, or knows a supplier? Siemens service is not able to supply it.
Any help is highly appriciated.
best regards,
Horst
Horst7000 is offline   Reply With Quote
Old 04-24-2019, 12:46 PM   #36
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
I have one however it will not help you.
The board needs to be reballed, I've had one done successfully by forum member Th3_uN1Qu3.
That said this is a difficult board to reball because it uses black glue under the chipset.
I have also had success with eBay seller hicomp-gmbh, however the price is about 10 times higher.
__________________
Per Hansson is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
