Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > All Others Motherboards
Thread Tools Display Modes
Old 05-14-2019, 06:21 PM   #1
gryffinwings
City & State: San Diego
My Country: United States
I'm a: Knowledge Seeker
Default Macintosh SE Capacitor replacements?
I'm currently working on disassembling my Macintosh SE FDHD. I would like to recap it. I've heard it's recommended to recap the analog board and the power supply, is it also recommended to recap the logic board? Also, does anyone have a capacitor list and maybe recommended replacements? I'm not familiar with what the Macintosh SE FDHD requires, but I have no issue with the actual process of replacing capacitors.
gryffinwings is offline   Reply With Quote
Old 05-15-2019, 03:16 AM   #2
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: Macintosh SE Capacitor replacements?
mac logic boards use mostly solid caps, you leave them.
although i would check that varta battery.
stj is offline   Reply With Quote
Old 05-15-2019, 10:45 AM   #3
BigTroll
BigTroll's Avatar
City & State: Jefferson
My Country: LAMBDA SOND
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
I found this thread https://68kmla.org/forums/index.php?...d-be-recapped/
I agree I would leave the axial caps alone unless you see crusted leaking from them. I have a SE I opened up 2 years ago, caps looked fine so I left it alone, however I did lube the floppy drive eject mechanism, that would be a good idea if you still have it apart. ditto the pram battery, vartas were the better pram batteries along with tadiran. luckily its not a maxell as ive had one ruin a centris 610 by spilling its guts all over the logicboard.
__________________
My Computer: AMD Ryzen 7 2700X, Asrock X370 Killer SLI/AC, 16GB Geil EVO X DDR4 3000, 500GB WD Black NVME and 2TB Toshiba HD,EVGA GTX 1080 SC, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
BigTroll is offline   Reply With Quote
Old 05-15-2019, 03:46 PM   #4
gryffinwings
Thanks for the link and the advice, I've got the battery and holder on order to replace the original, as well as a replacement fan which is whining pretty bad.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
