I recently decided to upgrade to an LCD Flatscreen monitor from a Philips 109S --- no monitor problems whatsoever previously. In fact, system running fine (mb is an ASUS P2B-D and is still going strong w/caps looking good).
Problem: The Acer 1906 (w/a 8 MS refresh rate) flashes to black screen every 2 - 7/8 seconds. Power light on the monitor is consistant. Only the screen itself flashes to black; no other problem apparent than this (i.e. no fluttering, distortion, etc. present).
My attempted solution: Check and properly adjust the monitor settings according to the video card. Check both video card (ATI 128 All-In-Wonder) and monitor drivers -- updated them to most current versions.
Called Acer -- tech had me check to see if problem exists when going into BIOS; it didn't, so he concluded the problem isn't with the monitor, it is w/the video card.
Called ATI; as the 128 AIW is no longer supported by them, I was advised all correspondance must go through email to their tech support website. Incidently, the CSR stated that w/current drivers for Windows XP installed (my OS), "Theoretically and technically, there should be no problems, as that card should have no difficulty supporting a plug and play device such as an LCD Monitor." Upon contacting ATI's email support, all I had told to me was to "get another video card because we stopped updating the drivers for that card and you need a fix in the driver in order to use that card w/your LCD monitor. So you have to get a different card to use that monitor." Riiiiiight.....
Okay, so I'm irritated. My hypothesis is that the problem lies somehow w/the 8 MS refresh rate -- that is my guess; even if this is the problem, what to do about fixing the flash to black? The 128 AIW is going strong! Why replace it when it isn't broken and is doing a fine job -- that is, fine but for supporting a lighter, more compact monitor instead of a lead-wght behemoth.... and what about that "theoretically and technically, there should be no problem"?
Can anyone please help?
