Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 11-27-2021, 10:01 AM   #1
Baldrick
City & State: Collegeville, Pa.
My Country: USA
I'm a: Knowledge Seeker
Default Samsung UN48H6350 - Going Crazy
Hi all. I've got a Samsung UN48H6350 that suddenly started going crazy.
The volume goes all the way up then down, inputs keep changing, it turns on and off. It's constant too. I unplugged all inputs from it thinking it might be a CEC issue with no luck. Unplugged it overnight with no change.
I did read something that said this is fairly common with some Samsungs. If this is a board swap, I was wondering if anyone knew about this issue and could tell me what board needs replacing.
Thanks!
Baldrick is offline   Reply With Quote
Old 11-27-2021, 02:50 PM   #2
handsworth
City & State: Cleveland, Ohio
My Country: United States
Default Re: Samsung UN48H6350 - Going Crazy
Im not familiar with the power button and Ir set up on this tv, but if they are separate, unplug the button setup and use the remote control. This was a common problem on older LCD Samsungs.
handsworth is offline   Reply With Quote
Old 11-27-2021, 03:41 PM   #3
Baldrick
My Country: USA
Thanks for the reply.
To me, it looks the IR and controls are tied together.
What I just did was unplug the cable coming from the IR/wifi/button module where it plugs into the main board. I fired it up and it does the same thing.
I'm assuming this is saying I need a new main board?
Thanks again.
Old 11-27-2021, 04:28 PM   #4
dskall
dskall's Avatar
City & State: Bakersfield ca.
My Country: usa
Line Voltage: 120VAC 60Hz
I would check voltages on mainboard connector with cable off and see if you have any voltages on the pins.
__________________
dskall is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
