Motherboard is Intel DQ35JO. They have notoriously bad caps below the 24 pin ATX connector (1800uf 6.3v Rubycon MCZ). I successfully replaced both with 2200uf 10v Panasonic FM's. Ran stress tests on the system for several hours and even with the system idle, the caps are measuring 45c on the vent with my k type probe using a multimeter.
I never knew caps to be hot to the touch like this before. Normal?
Yes I know the new caps are 12mm vs 8mm old and it looks bad but there in there good and working.
