Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Abit - Asus - Aopen
Thread Tools Display Modes
Old 02-10-2018, 04:31 AM   #1
ruky con
a fake rubycon
ruky con's Avatar
City & State: california
My Country: USA
Line Voltage: 122.5VAC 59.9Hz
Default Asus PTGD-LA with 3 dead NCC KZG capacitors
Hello, i was given a old HP PC which has a Asus PTGD-LA motherboard with 3 dead KZG capacitors on it (all three are 1000uf 16v) I'm looking at using polycaps for this recap, the capacitors i'm looking at right now are the NCC PSG series polycaps but i have not decided if i will go with polycaps yet. This is also the first motherboard i'm trying to recap (i would not care too much if i accidentally kill it) but if anyone has any tips on how to do it without killing the motherboard then i would highly appreciate if you could tell me.
Here is the best photo i could get of the motherboard as of yet.
__________________
(Insert Signature Here)
ruky con is offline   Reply With Quote
Old 02-10-2018, 08:20 PM   #2
Stefan Payne
City & State: Northern Germany
My Country: Germany
Line Voltage: 230VAC/50Hz or 400VAC/3P/50Hz
I'm a: Knowledge Seeker
Default Re: Asus PTGD-LA with 3 dead NCC KZG capacitors
Just go with Kemet A750, they are cheap and close enough to the original KZG.
Those PSG don't really make sense because they are darn expensive...
A750 are around half the price. And frankly, with a Board without an x16 PCIe I'd rather not invest much at all...
Is that really an i915 thing with a Pentium 4??
Anyway:
What you really need to do is kinda preheat the board because those PCBs can really suck up heat and is also designed as a heatsink in that area...
Do you have hot air station??
Or something similar??
That's rather important in this case...
Without it, you have a big problem...
Because its very hard to desolder them, even with a good iron...
So preheating it is the most important thing in all of this...
Stefan Payne is offline   Reply With Quote
Old 02-10-2018, 08:32 PM   #3
ruky con
a fake rubycon
ruky con's Avatar
My Country: USA
I was going to go with Kemet A750 but the earliest i can get them (from digikey) is 2 months.
Old 02-10-2018, 08:44 PM   #4
Stefan Payne
My Country: Germany
Mouser has a couple of them:
https://www.mouser.de/KEMET/Passive-...3&Ns=Pricing|0
And if you don't want to order @ mouser, you can still go with Pana FM.
They are a bit bigger than KZG - 10mm instead of 8mm but are a great replacement because about the same ESR...
Old 02-10-2018, 09:17 PM   #5
ruky con
a fake rubycon
ruky con's Avatar
My Country: USA
Quote:
Originally Posted by Stefan Payne View Post
Anyway:
I have a few hot air guns (one of witch can get hot enough to melt solder) but no real hot air station.
Also, i don't like to buy from mouser anymore because they tend to screw up my orders somehow.
I think the power supply may also be dead.
Old 02-10-2018, 11:10 PM   #6
ChaosLegionnaire
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist Tech
here's a better pic of the board off the net. from the OP's pic, it looked like the board only has 2 power phases for the cpu vrm which is misleading. it actually has 4 phases which makes it a suitable candidate for polymodding.
so i almost ended up trolling the topic because i thought the board only had 2 phases and shouldnt be polymodded...
ChaosLegionnaire is offline   Reply With Quote
Old 02-10-2018, 11:28 PM   #7
Stefan Payne
My Country: Germany
Quote:
That should be enough to "warm up" the board...
The Problem with those things is that they are unregulated and you have to be pretty careful to not heat the board up too much...
Quote:
hm??
Explain pls.
I want to know =)
Old 02-11-2018, 06:20 PM   #8
RJARRRPCGP
City & State: North Springfield, Vermont
My Country: USA
Line Voltage: 123-127V 61.5-63.5 Hz
Was that bulging and leaking just from sitting? The KZGs on my 2004 Asus A7N8X-X, looked like that, when just sitting!
__________________
Asus P6T Deluxe
Core i7 Extreme "Bloomfield" 965
PNY GeForce GTX 960
Windows 7 SP1
SoundBlaster ZXR
Corsair TX850M PSU
"Don't eat yellow snow!" -Salem
RJARRRPCGP is online now   Reply With Quote
Old 02-11-2018, 06:27 PM   #9
ruky con
a fake rubycon
ruky con's Avatar
My Country: USA
Quote:
I don't think so as there's one other KZG capacitor that is not bulging.
Old 02-12-2018, 01:48 AM   #10
Stefan Payne
My Country: Germany
Maybe, but it seems that this board only has three caps between +12V CPU and CPU VRM.
But another thing:
Why are both memory sticks on one channel and don't use both??
Old 02-12-2018, 02:06 AM   #11
RJARRRPCGP
My Country: USA
One day, I was in my bedroom, IIRC, (maybe another part of 105 Main St.) and decided to check my 2004 Asus A7N8X-X motherboard, which was just sitting in a room, and discovered that the caps were doing something that I never saw them do before, at least a fair amount of the caps, suddenly looked like a volcano!
Old 02-12-2018, 02:21 AM   #12
ruky con
a fake rubycon
ruky con's Avatar
My Country: USA
But another thing:
I have no idea why. :|
Old 02-12-2018, 02:50 AM   #13
ruky con
a fake rubycon
ruky con's Avatar
My Country: USA
So i said the power supply might also be broken broken so i took it apart and it was a really bad quality power supply.
But i think i may still have the OEM power supply somewhere.(i think it was a hipro)
You can see the garbage PSU here.
One last thing, this PC was given to me by my parents.
Old 02-23-2018, 08:07 PM   #14
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
You might want to remove that CPU heatsink and check what's under it (in terms of caps). Some ASUS boards come with Chemicon TMV, which are also prone to failure and should be replaced.
You could also go with Wurth Electronics polymer caps if you want to keep costs low. Series doesn't really matter that much with polymers - they would be pretty low ESR already. So pick whatever is available.
Couldn't have said it any better.
It really bothers me when I see otherwise okay-ish motherboards with no PCI-E x16 (or back in the P4 days - AGP) slot. Heck, even a PCI-E x1 slot would have been nice (could open it on the back and insert a full-size PCI-E 16x GPU then).
Nah, it's really REALLY hard to overheat a board with a heat gun - you'd have to have your heat gun on its high setting and heat for at least 5 minutes. If you're holding the board, you'd notice way before then, as it will start burning your fingers once things heat up to 55-60C. And if you have the board resting on something, you would start to smell the hot PCB once you go past 120-130C - which is still a fairly modest temperature that most components will withstand for a few minutes just fine.
Old 04-16-2018, 07:26 AM   #15
ruky con
a fake rubycon
ruky con's Avatar
My Country: USA
Finally got around to removing the heatsink and..... all of the caps under it are NCC TMV 680uf 4v...
though i do have some salvaged 560uf 4v polycaps and i wonder if i could get away with using them to replace the NCC TMV caps.
Here is a photo of one of the 560uf polycaps i was talking about.
Old 04-17-2018, 10:39 PM   #16
momaka
momaka's Avatar
My Country: U.S.A.
Would likely be fine. How many TMV caps are there on the board? If 6 or more, I would say it's definitely safe to replace them with the PSA poly's.
Old 04-17-2018, 10:48 PM   #17
ruky con
a fake rubycon
ruky con's Avatar
My Country: USA
about 10 of them, 5 of them appear to have failed based off the way they look (the rubber bung on the 5 of them appear to be pushed out).
Note: I just spotted another KZG cap on the motherboard that appears to have not failed yet, it's a 1500uf 6.3v cap.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
