Need help with buying soldering tools
    Hi
    Everyone marry Christmas first of all.
    I am new to forum and I like to ask that I need to buy tools for rework
    I am tight on budget so pleas bear in mind that I need not too expensive
    I need to buy soldering iron station and hot station with micro level tips as well
    And what microscope u suggest.
    Thanks is advance
    Re: Need help with buying soldering tools
    Tight budget = No profi tools
    Get a Bakku hot air station with two soldering terminals and buy a bunch of different tips in a larger quantity as they are cheap, buy quality tin wire, flux and chemicals, and as for the microscope buy an cheap Chinese USB microscope and get a nice and bright LED movable light as well as non corrosive non magnetic quality set of tweezers. Just with that you´re good to go.
      Thanks for your seggestaion should not I get separate hot station and iron with temperature control
        dont suggest to buy hotair with solder iron.
        that iron have low wattage. better buy independent solder iron with thermoregulation
          A good station for me is ersa rds80 , not for intensive work.
            Good solder station Weller WD1 and microscope Amscope zoom 45x
