Re: Jensen JE1907DC 12v RV TV
Ah... interesting. That amp draw would suggest an issue with the tv as it does appear to be over even the "regular power supply" capabilities.
Did you try the "disconnect the inverter" test that you did earlier to see if the power supply made a difference in the outcome.
You might have to try some other "disconnect test" to see what happens especially if you can get the backlighting to come on.
you need to post a picture showing how everything is connected up so people perhaps can make further suggestions.
