KT3 Ultra2-R (ms-6380E)
    Hello all
    Would anyone have a list of capacitors for this motherboard KT3 Ultra2-R
    (ms-6380E) I would like to order capacitors before taking my computer apart.
    Re: KT3 Ultra2-R (ms-6380E)
    Each board is outfitted with different brands caps. Some should be replaced and some should not.
    sig files are for morons
      The reason I asked for a list of caps for this board is hoping someone recapped the same motherboard and saved the list of cap ratings.
      Anyway my computer became very unstable so I replaced the one bad cap
      1000 uf 6.3v tepo with a 1000uf 10v fr Panasonic
      my computer works great till next cap fails
      What do you mean by some caps should not be replaced.
      Just in case any one in the future need a cap rating list for this board
      KT3 Ultra2-R
      (ms-6380E)
      1000uf 6.3v
      470uf 6.3
      1000uf 16v
      470uf 16v
      100uf 16v
        KT3 Ultra2-R
        (ms-6380E)
        1000uf 6.3v
        470uf 6.3
        1000uf 16v
        470uf 16v
        100uf 16v
        Can you measure the dimensions of them too? (In mm) Then we can refer you to some replacements from mouser, digikey, etc...
        Muh-soggy-knee
          1000uf 6.3v 6mm x 11
          470uf 6.3 6mm x 11
          1000uf 16v 12x20
          470uf 16v 7mm x11
          100uf 16v 5 mm x11
          Thanks ben7
            470uf 6.3 6mm x 11
            1000uf 16v 12x20
            470uf 16v 7mm x11
            100uf 16v 5 mm x11
            Thanks ben7
            Do you have an extra 2mm width and 4mm height to spare on all the 1000uF 6.3v capacitors? I can only find replacements in 8 or 10 mm width, and in 12.5 or 15 mm height.
            Anyways, here is a list, let me know about the 1000µf 6.3v capacitors before you order these:
            1000uf 6.3v 6mm x 11 >>> 1000µf 6.3v 8x15 Nichicon HM
            470uf 6.3 6mm x 11 >>> 470µf 6.3v 6.3x12.7 Panasonic FR
            1000uf 16v 12x20 >>> 1000µf 16v 10x20 Panasonic FM
            470uf 16v 7mm x11 >>> 470µf 16v 8x11.5 Panasonic FR
            100uf 16v 5 mm x11 >>> 100µf 16v 5x11 Panasonic FR
            Muh-soggy-knee
              Good list ben, except maybe using HM also for this:
              ...which is probably for the VRM high.
              Maybe this is better:
              http://www.digikey.com/scripts/DKSea...33766583940898 (Had to use 1500uF because of low stock for 1000uF).
                The link is broken, it says "part not found"
                I think the FM will be fine, the capacitors on the input of the VRM don't get stressed nearly as much as the VRM output ones. Besides, the FM has an impedance of 19mOhm, and rated ripple current of 2.18 amps.
                Muh-soggy-knee
                  Yea, you're right... Link works for me btw... (p/n UHM1C152MPD-ND)
