i have a msi nf750-g55 has 4+1 phase i was overclocking and vrm mosfet blew it had a heatsink,
nikos manufactor transitor 1 per phase p0903bdg, 2 per phase p70n02ldg. im going to replace p0903bdg with www.digikey.com IRLR7833PBFCT-ND, and replacing p70n02ldg with IRLR8256TRPBFCT-ND.
> for the origenal specs you can find them at datasheet archives. and replacing capacitors with bigger ones to help with the higher levels of energy at overclock speeds so i figure double should work. fujitsu is manufactor fp 02He 271 16 271uf 16v 8mohm with digikey number 493-3019-ND 470uf 16v 9mohm. replace fp 02ph 821 2.5 821uf 2.5v with 565-3221-ND 1500uf 2.5v 7mohm. i have the R50 choke inductor, i need to upgrade please advise origen specs so i can pick one out thats better. thanks tell me of what you think of this overhaul and anything i need to take into consideration with replacing with better parts. thanks agian
