I've run into this issue several times with computers I've sold. I know it's not a hardware problem, as it's occured with completely different hardware. It happens regardless of component manufacturer, chipset, HD manufacturer, etc. It happens on computers with perfectly functional hardware (it passes all tests). It happens on computers with a good sized APC UPS. As far as I can tell, it's a Windows XP problem and Microsoft doesn't know what it is and won't / can't fix it.
What happens is, after the system is in use for a period of time, anywhere from a day to 5 years, it will come up with "A disk read error occured Press CTRL / ALT / DEL to restart" right after post, before loading the OS. I've only seen it on computers with XP.
Sometimes chkdsk (from another computer) will fix it. Sometimes it wont. Sometimes changing the SATA cable will fix it. Sometimes it wont. Sometimes plugging the drive into a different SATA port will fix it. Sometimes it wont. Sometimes changing the drive from SATA 300 to SATA 150 will fix it. Sometimes it wont. It's a crapshoot, and I'm spending a lot of time on it when I could be doing other things. It sucks!
While troubleshooting this problem in the past, I've replaced hardware under warranty. I've taken this hardware, installed Linux, and it works perfectly! WTF? I'm even using a hard drive that had been getting this error every week, that I replaced, on my personal system running Fedora Linux. It's a 250GB Samsung. It's been running for a year and a half perfectly.
So anyway, what the **** is going on? Is XP really that unstable? Has anyone else on here seen it? Does anyone know how to prevent this error, or at least what is causing it?
