Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 12-06-2017, 04:49 AM   #1
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
Default Repaired Shear Back Stop Key Pad Enter Key not working
This was a real fun repair that I wanted to pull my hair out not that I have much hair left
We got this hand me down Shear from one of our other location—>
When first turn on the Shear the digital display would keep flashing the digits one at a time and the desmail point would also flash on and off
Took out the controller boards and recap them put them back in now the digits do not flash as much but now the enter key works when it felt like working
Took the controller boards out again and replace the MM74HC373N five of them
One LT1013CP and four of the 2N4401
Now every thing works the way it should work
File Type: jpg 22B4FF7F-A238-4D5E-B95C-60AAB33EC01F.jpg (416.1 KB, 18 views)
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 12-06-2017, 07:31 AM   #2
sam_sam_sam
My Country: USA
Default Re: Repaired Shear Back Stop Key Pad Enter Key not working
Also the touch pad was replaced which did not change one thing about the way it was working
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
