CH341a programmer
    CH341a programmer
    latest free software - for anybody who needs it.
    i pre-configured it for english menu's.
    also latest drivers that also work for 64bit and win7
    Re: CH341a programmer
    Thanks stj i will use this updated version.
      Thank you sir!
        Thank you sir!
          Thank you sir!
            Thank you
              well done thanks
                Thank you
                  Is this sw for the 'black version' ?
                    for either.
                    if you have the black one, put the jumper on pins 1&2
                      Hello STJ.
                      I bought a usb ch341A.( black version) I use your program. Everything work very good so far.
                      Computer see my new usb (connected).
                      I have question eeprom 24C . Can I write to new eeprom 24C.? Look like it
                      can read only.The seller post on ebay.
                      :"USB Programmer CH341A Series Burner Chip 24 EEPROM BIOS LCD Writer 25 SPI Flash ":
                        it can read and write - no problem.
                          STJ
                          The program works good. I do not know why it do not detect 24C eeprom. It only detect
                          25 chip
                            maybe try the software in this you tube link im sure 24c eeprom do get detected its been ages since ive used this programmer though but the software in kris links works fine.
                            https://www.youtube.com/watch?v=L0ChYNwunUE
                            https://drive.google.com/file/d/0ByE...ZOUGtLcnM/view
                              Thanks vinceroger69
                              I will try . I will let you know. I need to program a tv board that I am working with.
                                you cant "detect" 24 series eeproms because they dont have a manufacturer and product id for the programmer to read.
                                the 24 series is too old for such features!
                                dont forget that 24 series goes in the other half of the chip socket on the programmer.
                                  Thank you stj.
                                  My chip is 25lxxx EEprom. It is a bit hard to read the label of ic. It can not identify the ic producer but programmer read the content.And also It can write the ic.
                                    Brilliant! thanks for that,STJ!..
                                    Just wondering how to read and copy from 25xx to pc?...sure i will work it out.
                                    Not a bad little unit overall!
                                    Steve.
