Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals
Old 09-04-2016, 10:10 AM   #41
diif
City & State: Midlands
My Country: England
Default Re: P5PE-VM question ?
The black connector on the board or leads with probes soldered to it.
diif is offline   Reply With Quote
Old 09-04-2016, 06:16 PM   #42
bianchi77
City & State: Western Australia
My Country: Australia
Line Voltage: 220AC
I don't understand ? which black connector....which probe ?
bianchi77 is offline   Reply With Quote
Old 09-04-2016, 06:19 PM   #43
bianchi77
Line Voltage: 220AC
Here's the voltage I got on the FETs at the board...
There's a possibility that my buck controller is faulty and it's a clock generator as well...
CLK865J02FLF....the issue is, I can't find datasheet of it...
Old 09-08-2016, 04:07 PM   #44
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
The voltages look good to me, so I don't think the buck controller is bad. Only the voltage at the Source of Q10 doesn't seem right (should be the same as Q6 and Q8). But I think you just didn't measure it properly, because Q11 does appear to have the correct V_core voltage on its Drain.
Anyways, what I am more worried about is all of the KZG caps I see scattered everywhere on the motherboard. Unless you have pulled out each one from the motherboard and checked it for proper capacitance *and* ESR, there's no telling if that's the problem or not. (And also, sometimes an ESR/capacitance meter can be fooled by an electrically leaky electrolytic capacitor, so keep that in mind if you did test all of those KZG caps. In particular, anything that reads over 20% of the nominal capacitance could be leaky).
Old 09-08-2016, 06:31 PM   #45
bianchi77
Line Voltage: 220AC
which one are the KZG caps ( what color ) ? I haven't tested them with ESR meter, I don't have it yet ....does it mean that I need to desolder them all ?
Old 09-08-2016, 06:36 PM   #46
bianchi77
Line Voltage: 220AC
I have a capacitance meter, it can read capacitance and impedance, but no ability for reading ESR...would it be good enough testing them ?
Old 09-08-2016, 06:38 PM   #47
bianchi77
Line Voltage: 220AC
Are you talking about the capacitors on FET filter to Vcore ?
Old 09-08-2016, 06:38 PM   #48
bianchi77
Line Voltage: 220AC
I can pull them out test and replace if needed...
Old 09-08-2016, 07:05 PM   #49
RJARRRPCGP
City & State: North Springfield, Vermont
Line Voltage: 118-127V 59-63.5 Hz-> actualizo: pérdido de voltaje
It was long beep, short beep, short beep
That's an AMI BIOS RAM init failure code...
MSI B450 Tomahawk
Ryzen 7 "Matisse" 3700X
16 GB Corsair Vengeance LPX DDR4 SDRAM
Zotac GeForce GTX 1660
eVGA Supernova G3 750W
"Don't eat yellow snow!" -Salem
RJARRRPCGP is offline   Reply With Quote
Old 09-08-2016, 07:06 PM   #50
bianchi77
Line Voltage: 220AC
are those KZG capacitors, you're talking about ?
Old 09-08-2016, 07:16 PM   #51
RJARRRPCGP
Those are the ones! Almost always brown...
Old 09-08-2016, 07:19 PM   #52
bianchi77
Line Voltage: 220AC
Are they most likely faulty ?
Old 09-08-2016, 08:12 PM   #53
bianchi77
Line Voltage: 220AC
I've measured some of KZG caps you're talking about...
Measurement in circuit...they give me value...some of them 33K, some of them ..87K...
are they bad ones ?
Old 09-08-2016, 08:23 PM   #54
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
Well, I don't have X-ray vision so I can't give you a verdict from the comfy seat of my chair... but all I can tell you is that those Chemicon KZG capacitors do fail quite a bit, and sometimes without visual signs too.
Impedance and ESR become close at relatively high frequeincies (around 100 KHz), so yes you can *probably* use the impedance on your meter. Speaking of which, what meter is it?
If you want to test them, YES.
In-circuit readings on motherboards are often inaccurate and/or total garbage. So remove the caps and test. Better yet, if you have good quality low-ESR replacements, just replace those KZG caps and at least be done with that part. Then you won't wonder if bad caps were the problem, at least.
Also, the black caps around the CPU appear to be Panasonic FL (4V 680 uF). Panasonic makes very good caps, but even these can go bad simply because of where they are placed - right under the CPU heatsink. If a hot-running CPU was used, they could be dried out. I recommend getting polymer caps for those positions.
Old 09-08-2016, 09:19 PM   #55
bianchi77
Line Voltage: 220AC
It's atlas LC-45....it can test on 200KHz frequency...but can it be done in circuit ?
What value should I see on it ?
It's easier when it's in circuit...but I'm not sure if the value is valid, because it's connected to other components...
Old 09-08-2016, 09:42 PM   #56
bianchi77
Line Voltage: 220AC
Here's the value I got for in circuit test with LCR-45...
Frequency = 200KHz...
Impedance (Z) = -163.1mOhm - j57.69mOhm...C = 1.2 uF
The capacitor value on the label is 1000uF....and it looks like parallel with the other 4...
Any ideas with those figures ?
Old 09-08-2016, 10:01 PM   #57
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Of course it is easier to test the caps in the circuit but the result you get will not be right dues to the fact that also have other components connected in parallel with the cap. You can waste lots of time doing short cut.
Why don't you just experiment by measuring spare known spec. caps with your LC-45 to see what reading you get, and then just try removing just one of the paralleled cap off the board and test it and see what you get?
Or get the same set of caps and connect them in parallel just like what are on the board and take the reading and compare to what you get with the reading on the board.
Experiment, Experiment, Experiment to see what your test equipment can really do and understand what you are testing and understand the result.
Old 09-08-2016, 11:34 PM   #58
bianchi77
Line Voltage: 220AC
Ok...I'll do some experiments with parallel capacitors off the board ...and see the value...
Old 09-08-2016, 11:56 PM   #59
bianchi77
Line Voltage: 220AC
I got -155.2 mOhm + j4484 mOhm for 2 1800uF brand new in parallel off circuit...
It might be the caps on mobo are ok...but...I'll desolder one of them anyway as you said...
Old 09-09-2016, 01:02 AM   #60
boyebaran
City & State: tehran
My Country: iran
Line Voltage: 220VAC 50Hz
if u change cap and mobo did not work you can check North bridge for disconnecting from board. you can push north bridge hit sink vertically by hand and starting motherboard. better you warm a little under north bridge by hitter before pressing north bridge.
boyebaran is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2020
