Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Abit - Asus - Aopen
Old 08-10-2016, 04:24 AM   #1
bianchi77
City & State: Western Australia
My Country: Australia
Line Voltage: 220AC
Default Asus M2A-VM no display ?
Guys,
I got Asus M2A-VM....CPU fan is spinning ok, but no display or beep ?
Is it possible that the firmware is corrupted ?
THanks
bianchi77 is offline   Reply With Quote
Old 08-16-2016, 10:23 PM   #2
kaboom
"Oh, Grouchy!"
kaboom's Avatar
City & State: PA
Default Re: Asus M2A-VM no display ?
blown southbridge?
what are you powering this with?
did +5vsb ever "run away?"
"pokemon go... to hell!"
EOL it...
Originally Posted by smashstuff30
guilty,guilty,guilty,guilty!
guilty of being cheap-made!
kaboom is offline   Reply With Quote
Old 08-23-2016, 11:41 PM   #3
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
You keep asking this question. But we can't really answer that when you don't post more information about the motherboards and your testing setup.
How about tell us:
- Where you got the motherboard and do you know anything about its history? ... like, did it come out of a computer with a bad power supply? Was it yours or someone else's? If yes, did you get it in non-working condition?
- What power supply, RAM, CPU, and video card (if applicable) are you using to test this motherboard?
- CMOS battery okay? (i.e. reads close to 3 Volts?) Tried reseting CMOS?
- Does the motherboard look okay? Any deep scratches on the back or front? Any bad cap brands? (even if none look bad.)
The more information you give is, the more likely we can help you narrow down the problem. That said, I will give you an answer to the question you asked above: YES, the "firmware" / BIOS *may* be corrupted. But it also might NOT be. It's pointless for us to even attempt to answer that, though, when we don't know anything about the motherboard.
The issue you are having (motherboard turns ON with fans spinning, but NO display) is an extremely generic failure mode and can be caused by so many different things. You gotta narrow it down before deciding it must be the BIOS gone bad or something like that.
Also, from what I remember from your other thread, you were using a Deer/L&C/Allied or some similar PSU (please correct me if I a wrong here). If that is still the case, you need to either get a better PSU or make sure that one is recapped with good Japanese caps and has all of the proper filtering parts both on input and output side (especially the "PI" coils/inductors on the output). If it doesn't, don't bother recapping that PSU or using it for that matter.
Old 08-23-2016, 11:53 PM   #4
bianchi77
Line Voltage: 220AC
It's running already, thanks guys
Old 08-25-2016, 12:04 PM   #5
mikail13
City & State: istanbul
My Country: Turkiye
How?
mikail13 is offline   Reply With Quote
Old 08-25-2016, 05:54 PM   #6
bianchi77
Line Voltage: 220AC
Sorry, I've forgotten already how I fixed it...few weeks ago..
