From what I've read, LED backlights on TV's run between 90V to 120 vdc. I know my power supply is bad but want to build a LED tester to see if my LED's are good. If they are bad, I will stop any further work in trying to fix the TV since replacement LED strips are not available for this set, which limits me to replacing individual LED's, which I do not have the tools for at the moment.
Anyone built their own LED test power supply?
For a crude LED tester, I was thinking of using 120 v ac line voltage, a half wave rectifier, a 500 uf filter cap and a current limiting resistor. The half wave is so I don't exceed the 120 vdc, but will give more ripples. Full wave will have less ripples, but the voltage may end up at around 150 vdc. LED's are current driven devices. Maybe a full wave should be fine as long as my current limiting resistor is the correct value and not exceed the current rating of the LED's.
How do I find the total LED current rating of my set? It's a 50" Toshiba 50L2300U. What is the approx. current to the LED's of a a 50" TV?
