Amilo xa2528 /xa1526cooling trick
    So everybody knows that they are like saunasbut i add approx 0,5 cm and 10cmx10 aluminum pad top of the gpu and the temps are right now on idle about 32c and under pressure approx44c ,huh whadda difference..so if you own that pc you should do it also..it hardly pushes out warm.
    Re: Amilo xa2528 /xa1526cooling trick
    0,5 thick i meant
      cool.
      My pc
      CPU : AMD PHENOM II x4 @ 3.5Ghz
      MB : ASUS M4A89TD PRO USB3
      RAM : Kingston ValueRAM 16gb DDR3
      PSU : Cooler Master 850W Silent Pro
      GPU : ATI Radeon HD 6850
        The classic copper shim mod? Good idea, works for pretty much every laptop.
        I can put text here?!
          Oh no!i added top of the heatpipe and gpu coolant plate another aluminium plate which is approx 0,5cm thick or fat and same size..the copper shims also but thats the old story
