Endless repeated beep ?
    Guys what does it mean by endless repeated beep ?
    Is it incompatible CPU ?
    Diagnostic POST showing C1C1....
    Re: Endless repeated beep ?
    Why don't you check the website of the motherboard vendor and the cpu compatibility list ?
    What's the point of owning a card if you don't know what the error codes mean ?
    Have you got a GUARANTEED WORKING stick of memory with no faults in ?
    Have you tried another CPU ?
      I don't have another CPU....I reckon the CPU is not compatible...I used Celeron D 346
      I can't find the meaning of ...Beep-beep-beep repeating
        if its an award bios board, it should mean memory not present or bad. try another memory module. if it still doesnt work, try another dimm slot. it could be one or more bad dimm slots.
          I have no idea which BIOS is it....how can I see it ? I can only see the motherboard type....looks like it belongs to HP but the motherboard is MSI
            the board code is MS-7352
              http://www.findlaptopdriver.com/msi-...ons-20h090712/
              BIOS = unknown
                BIOS :
                http://h20564.www2.hp.com/hpsc/swd/p...&swEnvOid=1098
                  Is your memory a known 100% working compatible stick ?
                    Yes my memory is a good one, tested already...boot until linux and stable...
                      Could it be CPU matter ? but it's LGA 775...from I can read and learn...there is some different core for LGA 775, that's I've been thinking...
                        Booting Linux is not testing the memory. Test the memory fully and report back.
                          If it doesn't work it will not work on another board n boot until OS
                            Use memtest86.
                              memtest is dos based?
                                yes
                                  msi sometimes uses either award or ami for their bios so guessing what bios vendor it is could be tricky. but if its ami bios, a post code stop at C1 means it stopped at setting the processor boot strap information. maybe cpu not recognised or supported by the board? try another known working cpu with a slower fsb?
                                  this is either a ram/cpu not recognised or supported problem.
                                    I've tested with Celeron D 346
                                    and from this :
                                    http://www.findlaptopdriver.com/ms-7...-support-list/
                                    I can not find it.....do you think, it's CPU incompatible issue right ?
                                      Or faulty memory !
                                        I haven't put any memories on it so I reduced the posibility of faulty memory...
                                        trying to debug it one step to another...
                                        There's a possiblity on memory as well...but in this case I didn't put it yet...how can the software at BIOS saying it's a faulty one unless it's doing something quirky..??
