3 long beeps ?
    3 long beeps ?
    Guys,
    I got one motherboard with 3 long beeps, what does it mean ?
    Re: 3 long beeps ?
    Faulty memory.
      Re: 3 long beeps ?
      I pulled out all of memories...still the same...any ideas ?
        Re: 3 long beeps ?
        What's the solution ?
          Re: 3 long beeps ?
          I got POST code 55...which mean no memory...but when I put memory on it...still the same ?? is the memory can not a proper voltage ?
          1.8V for memory right ? I haven't checked the motherboard type...I'll post later...
          I can only see a PCB code but not manufacturer name...only Intel...
            Re: 3 long beeps ?
            could it be something wrong with my RAM socket ?
              Re: 3 long beeps ?
              It could be a faulty socket, the incorrect speed or just a dead or faulty memory stick.
              Always check with a known working stick.
                Re: 3 long beeps ?
                the memory stick is working well on other motherboard...
                how can I check a faulty socket ? it'll beep if there's memory or not...
                here are some photos of this motherboard
                it's intel desktop DG31PR
                Memory:
                http://www.intel.com/content/www/us/....html#features
                Processor:
                http://processormatch.intel.com/Proc...entName=dg31pr
                  Re: 3 long beeps ?
                  Is it matter of incompatibility processor ?
                  I put celeron D 346 on it....probably that's the cause of triple beep ?
                    Re: 3 long beeps ?
                    Photos :
                      Re: 3 long beeps ?
                      Sounds more like bad RAM slot contacts...
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      16 GB AData XPG Spectrix D41
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                        Re: 3 long beeps ?
                        How can I fix RAM slot contact ?
                          Re: 3 long beeps ?
                          clean the RAM slot contact with isopropyl alcohol ?
                            Re: 3 long beeps ?
                            It's working now, clear CMOS...it didn't have a header only a solder bulb on the board...
                            I run linux now for a test....2Gbytes of RAM
                              Re: 3 long beeps ?
                              Linux running on it..
                              Thanks guys for the advice..
