Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 10-17-2020, 06:40 PM   #1
electrobe
City & State: canton, ga
My Country: usa
I'm a: Knowledge Seeker
Default Sharp LC-60LE650U
I have a Sharp LC-60LE650U that shuts on and off with only Sharp logo displaying before it goes off then repeats. When the tv is powered on the standby light is blinks once then goes off for a count of 2 then then repeats same. I could use a schematic for this model if available.
electrobe is offline   Reply With Quote
Old 10-18-2020, 06:53 AM   #2
electrobe
My Country: usa
Default Re: Sharp LC-60LE650U
Hello I wanted to check to see if any of you may have a schematic for this Sharp model tv
Old 10-18-2020, 09:14 AM   #3
nomoresonys
City & State: midwest
My Country: U.S.
More than likely a probem with eeprom/spi/nand on the mainboard, easiest fix is a replacement mainboard if that is the problem.
__________________
1) https://www.youtube.com/watch?v=4F2J1Dkf4Is
HIGH VOLTAGE HAZARD demonstration. Video by Electronic Doberman.
Always happy to help decent people save stuff from the landfill and I'm always open to a good stock tip, Thanks.
nomoresonys is offline   Reply With Quote
Old 10-18-2020, 09:47 PM   #4
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
1) There is not much info in the service manual. https://www.manualslib.com/manual/11...-60le650u.html
2) I have error codes for 640 so it may be closed enough, see attached PDF. ou should re-verify the blink code again Example of error code: https://www.youtube.com/watch?v=jHjBjIaQzXc
3) Show us good clear pictures of the whole backside of the TV showing all the boards, the good clear straight shots of the whole power supply board.
4) What Voltage testing have you done on the power supply connector that goes to the main board?
__________________
budm is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
