OC'ing Core 2 Duo/Should I?/Testing?
    Re: OC'ing Core 2 Duo/Should I?/Testing?
    Originally posted by kaboom View Post
    That's not what I expect from you! Where's the guide to change the feedback resistors in the VRM to get any voltage we want?
    Funny thing is, it would be possible if it wasn't all SMT...
    -Paul
    I believe the VID pins are still handled the same way so a jumper block could be patched into the PLL chip with a steady hand, a sharp iron tip and a magnifier. Just like the old days.
    A working TV? How boring!
      How 'bout in a nasty, POS, fugly HP/Compaq?
      That board is too good for a Compaq.
        And WAAAAYYYYYY too good for an Acer.
          i got a dg31pr for $26 it was on clearence i got the cpu 2.13GHz c2d for $30
          My Computer.
          AMD APU A4-3300 2.5ghz 1mb cache
          Motherboard GigaByte GA-A75M-S2V
          Kingston HyperX Blue DDR3 8GB (2x4GB)
          SB Audigy 2 ZS [B800] Sound Card
          500GB WD Caviar® Blue™
          1 Terabyte WD Caviar® Black™
          2 Terabyte WD Caviar® Black™
            i did a bios flash on an ecs/evilmachines for a friend.that is after a polymod.
            overclocked his e2100? to near double with 24/7/365 100% cpu load stability.
            recapped the bestec bomb too.too bad his crackhead gf stole it.i wanted to see how long it would last.wonder if you can trace it through boinc?
              C2D's overclock well if you dont have a shit mobo. I have a few and my best one as far as biggest overclock from stock is a 4300 1.8 800fsb overclocked to 3.6 on air using a ASUS P4ND2SLI mobo.
