gateway essex
    gateway essex
    ok i need a second opinion on this dose this look like this cap is bad my computer was fine untell it randomly properly shut its self down this morning and now it wont torn on its intermittently restarts
    all this falling a event where it was like a strobe light in my room last night of power during a rain shower like 10 seconds of power flashing like a strobe light but the computer was fine up tell now
    i was able to get too the bios for like a minute before it went out and started this
    the only thing i did not take out in the cpu and i do have the old one still
    its cap in the first 3 pics and the last 3 pics next to the plates . sorry about the flash interfering
    Last edited by rickybennett; 09-04-2012, 12:59 PM. Reason: uploaded 3 more better pics
    Re: gateway essex
    will at 5pm with nothing but the cpu and the 2 1gig ram sticks in it booted to the bios then went back out and started the intermediate maybe the power supply ??
    ps sorry for double post cant find edit button lol
      Re: gateway essex
      Looks like evercon, in a mix of ruby's and nichicons!
      Yep, its bulging, but I'd be surprised if it's the culprit.
      Yes, try opening the PSU. What brand is it?
      Muh-soggy-knee
        Re: gateway essex
        Cap does look slightly bulged as you say check the ones in the power supply.
        Have you tried cleaning the ram sticks does it work with just one? try changing them over.
          Re: gateway essex
          That cap looks bloated, but it could be angle/flash.
          Check your power supply for bloated caps.
          edit: Late to the party again.
          --- begin sig file ---
          --- end sig file ---
            Re: gateway essex
            i did check the power supply i did not see nothing out of the ordinary i ordered a cheap power supply tester though off eBay
            i swapped both around and got nothing but the same intermittently restarts
            did get in to the bios for like 1or 2 min before the intermittently restarts started again that was with both sticks of ram in it and my 3.06ghzHT cpu all was being detected at that point
            the power supply is a liteon mode#.ps-5161-2g output 160w min it diffidently needs a upgrade ether way
            i never changed a power supply before so if i need a new how about some recommendations
            oh and btw that cap is a 25v 100uf if you cant tell
              Re: gateway essex
              In another thread someone did suggest a complete power down. You switch it off as normal then unplug EVERY external cable then hold in the power on button for 30-60 seconds.
              Then plug it back in and restart. I dont think it worked in that particular case but has to be worth a try.
                Re: gateway essex
                Also in that last picture there is a voltage regulator ( may even be connected to that bad looking cap) Perhaps you can test it?
                See retiredcaps guide
                https://www.badcaps.net/forum/showthread.php?p=261329
                  Re: gateway essex
                  i don't quiet understand them instructions
                  is there by chances a video any where that would be help full
                    Re: gateway essex
                    ok so the power supply appear to be ok all the lights on the power supply tester lit up and when i hooked the mother board back up to the power supply and turned it or it booted up to windows and stayed on and i was able to do test with pc doctor which also passed all tests
                    but i do need to replace that cap which i know was never like before that night
                    its a 25v 100uf cap what do you all recommend for a computer motherboard last time i did this was on my lcd hd tv
