Gateway FPD1530 works for a second then dark
    Re: Gateway FPD1530 works for a second then dark
    Sorry, just got back from a trip
      Read this: https://www.badcaps.net/forum/showthread.php?t=1868
      Then properly post a picture of the bottom of the board. I suspect you have a totally different monitor.
      PlainBill
        The monitor is indeed a Gateway FPD1530
          I'm not sure why, but the back board pic isn't working
            I believe the picture limit size is 2000x2000. You can crop out your carpet in the pictures to lower the size.
            In addition, the owner of this forum has been making changes in the last 3 or 4 days, but has not posted a notice that I'm aware of, and the site has been up/down lately.
            --- begin sig file ---
            --- end sig file ---
              1) DMM in diode test: Test diodes D15, D16, D12, D8, D14 both directions and post results
              2) better pic of bottom. Take clear closeup of the entire right half of the board (side with discoloration). And I'd prefer they not be posted inline, just attached with the thumbnail...
                I did crop the pics down to a 1200x800. I thought the board would automatically resize them to a small size and make them clickable to a larger size.
                  Here's a closeup of the discolored side of the board.
                    OK... I see how it's done now. I thought I had to add the image from the attached files to the text area with the IMG tags or they wouldn't show
                      What are those diode readings I asked for?
                      Note: To get clear pictures, you need to do the following:
                      1) Put the camera in Macro mode (Usually identified by a flower)
                      2) Turn off the flash
                      3) Use sunlight for light source
                      4) Take picture directly above board, not at an angle
                      If it's still blury, use a tripod or steady you hands against something firm.
                        I don't have any knowledge of how to test things or what readings go with what. I don't have anything to test with either. I mainly was asking what the two 1Uf caps mcfischer was referring to when I first posted in this thread.
                          The 1uf caps in the first post are at location C106 and the one just left of it (just above ZD101).
                            I can't find anything that resembles the 2 you mentioned. I must be blind
                              Look at the picture in the very first post. It near the very top in the middle right by the Delta.
                              That is why PlainBill wanted pictures of your board. It looks like the picture in the first post and your board are NOTHING alike.
                              It is not uncommon for different board revisions to exist in the "same" monitor.
                                That explains alot... I have a completely different board in mine. In fact, the power wire and video cable are soldered right to the boards. No connectors
                                  Now that we are all on the same page, check
                                  1) glass fuses and picofuse to see if they are open
                                  2) test transformer using ohms
                                  3) check for cracked or poor solder joints
                                  for starters.
                                    I ended up just chucking the monitor to the recycling center. I replaced the caps and still nothing. Now back to trying to fix the little Dell 17"
                                      How do you know what volts they are at? There was another monitor with repair of the 680 uf cap needed and the cap read "25 V". But these are too small and have no writing on them that I can see. Maybe I need a bigger magnifying glass. Anyone know what is the voltage on this one or is it important, what range will work?
                                      Thanks!
                                      ADMIN: please change my ID from fairfbro to fairbro, or can you delete me then I can re-register? Thanks!
                                        The voltage is written on the cap, but you may have to remove it from the board to actually read it.
                                        The voltage of cap has to be the same or higher than the existing one. For example, if the cap is 1uF 25V, you can substitute with a 1uF 35V.
                                        A clear focused picture ALWAYS helps.
                                          You'll have to PM Topcat about that one I can't edit usernames.
