Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Thread Tools Display Modes
Old 05-03-2018, 03:40 PM   #1
dreico33
City & State: La Paz
My Country: Bolivia
I'm a: Knowledge Seeker
Default Soldering Equipment
Hellow Everybody,
I am new in this forum so if i'll say anything silly i am sorry,
Like the title says i am looking for soldering equipment. I am on budjet so i'll not go for high end equipment.
Can you tell / propose :
1 .Soldering Station
2. Hot Air Station.
I would go for Hakko but the prices of 220 v are ridiculus in comparison of 110 v.
I have heard that some stations can accept hakko tips which are all in one ( tip + heater ) .Is that true?
I am bettwen atten and aoyue but any recommendation is very welcome.
Thank you.
dreico33 is offline   Reply With Quote
Old 05-04-2018, 04:20 PM   #2
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
Default Re: Soldering Equipment
Are you also looking for a Desoldiering Gun Station if so I can give you a link to some
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 05-05-2018, 05:56 PM   #3
dreico33
My Country: Bolivia
What about the ATTEN St Series? Is it Reliable?
And for Hot Air Station the Atten 858d+???
Thank you
Old 05-05-2018, 10:26 PM   #4
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Define reliable.... It's cheap Chinese gear. It'll work, but it won't be amazing. On the other hand, spare parts might be cheap, too!
I'd personally go with the basic analogue versions. Less stuff to break so should be more reliable... A basic op-amp control circuit is easier to repair than something with an unknown micro-controller.
__________________
-David VanHorn
Agent24 is offline   Reply With Quote
Old 05-06-2018, 09:36 AM   #5
dreico33
My Country: Bolivia
I just want to find the balance between price and performance. I am not gonna buy something high end. I am planning to do some basic motherboard repair. ( Caps Dc Jacks Usb Ports Etc). Reliable well with the meaning of durable.I know the more expensive you buy the less possibilities you gonna end up buy another station after some short period of time.
Konstantinos.
Old 05-06-2018, 10:08 AM   #6
awyatt2
awyatt2's Avatar
City & State: Gaffney, SC
My Country: america
Line Voltage: 120vac 60hz
I have a yihua 952d+ had it for over a year now and it does very well, no problems so far I use hakko tips on the wand and the tips for hot air are the ones that came with it. its probally a knockoff of the aoyue but it has been dependable.
awyatt2 is offline   Reply With Quote
Old 05-07-2018, 04:34 AM   #7
mmartell
City & State: Windsor ON
My Country: Canada
For an iron there's alot of good press on the cheap TS100 (google it). As to reliability it may be too early to tell...
mmartell is offline   Reply With Quote
Old 05-07-2018, 08:13 AM   #8
Y. Signal
City & State: Andalucía
My Country: Spain
If you go for the Yihua 858D or other el cheapo chinese gear please check it before use since it may have serious design flaws: https://www.youtube.com/watch?v=A319o8Ji4oI
Y. Signal is offline   Reply With Quote
Old 05-07-2018, 02:48 PM   #9
awyatt2
awyatt2's Avatar
My Country: america
I did redo mine so the fuse is on the white wire, all ones from china have the same setup ,ground fused, as far as grounded tip the ground to case was fine.
Old 05-08-2018, 06:39 PM   #10
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
For a soldering station, I recommend anything that uses a T12 or T15 -type of tip. These are the ones that have the heating element and sensor built into the tip and they have pretty good performance, especially considering their price ($2-3 USD per tip usually). AVOID stations that come with "900M" style tips.
As for the station itself, go with whatever your budget allows. That said, I do recommend getting a station that has at least 60 Watts of output if you plan to do work on motherboards. I have a 75 Watt station (CSI 2900 - a close of the Aoyue 2900, I believe) and with several large tips (namely a T12-D52 bevel tip), there's almost nothing I can't desolder with it. I even often use it with my 30 Watt soldering iron to remove TO-252 MOSFETs directly from motherboards without hot air or pre-heating.
Now, for hot air... I can't really make a good recommendation. I acquired a KADA 852D+ from a friend of mine a few years ago and I still haven't outgrown it. But then again, I hardly do any work that requires hot air anymore, so I can't make any suggestions. I have heard that stations with a fan in the handle (not an air pump in their base) a better. I've used one briefly, and indeed they are more quiet and just as powerful (if not more powerful), so they may indeed be better. They are pretty cheap nowadays too.
Whatever you get, I do recommend that you open it and double-check all the wiring and soldering before powering it on. It's possible that some of these stations may have safety flaws. The majority of them, however, are just built too cheaply and so may have crappy soldering that needs fixing.
Old 05-08-2018, 07:46 PM   #11
dreico33
My Country: Bolivia
Thank you very much for your answers guys.
As for the solder station can you recomend me a t12 - t15 solder station?? ( Not Hakko Not 110 Volts I Nedd 220 Volts)??
And as far for the Hot Air Station i'll go either 858d+ o 852d+. Can you recomend me a good one?
Lastly i was wondering if i need a pre-heater for desolering Smd or Any Kind of PuchThrough Devices (Usb Dc Jacks Hdmi Ports etc) or for this kind of work you only need a Hot Air Station.
Thank you very much guys one more time/
Old 05-12-2018, 05:45 PM   #12
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
I'm a: Professional Tech
If you are after a hakko hot air station then you might consider a second user FR802 or 801, they seem adequate and can be obtained on the second hand circuit cheaply. I find it adequate for my professional work until such time as I find something better. Now as to soldering equipment all of my other soldering stations and hand pieces are Pace, will provide a list if you are interested.
llonen is offline   Reply With Quote
Old 05-21-2018, 03:19 AM   #13
tomodachi
tomodachi's Avatar
City & State: Istanbul
My Country: Turkey
Line Voltage: 220
For the hot air station I strongly recommend Quick 861DW,
see; https://www.youtube.com/watch?v=ChujyTV-HME
tomodachi is offline   Reply With Quote
Old 06-09-2018, 10:02 AM   #14
sn4k3
City & State: Alvito
My Country: Portugal
Line Voltage: 220VAC 60Hz
861DW for hotair.
Soldering station: ERSA Nano or ERSA I-CON 1
If you want go cheaper you always have the T12 clones and TS100 which is great with minor modding eg: https://www.ebay.co.uk/itm/TS100-Sol...3NymjL1fIO7esg
sn4k3 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
