Asus x441UV rev 2.1 bios need to fix
    Re: Asus x441UV rev 2.1 bios need to fix
    can someone fix my bin file,,
    laptop cant detect harddrive
    there's no barcode on motherboard
    heres my original dump,,
    thank you in advance
      Become a Badcaps supporter
      Thanks to all supporters.
        Originally posted by peste View Post
        try..
        Thanks colleague, it helped me, but a query, how does the bios work when it comes out as extracted in the analyzer and not a stock one?
          What would be the recommendation, of the bios that works to make this a clean me or not?
            X441UV Bios Problem
            Colleagues I have an ASUS X441UV board but it turns out that I put clean bios working on another computer and on my board it doesn't work even cleaning the ME region and nothing but, I found a bios of an X441URK and with that bios it does give me an image but it takes time to give image ? What will be the problem? One detail is that I have the ram that is soldered on just that plate disabled.
            There is a theme of a plate just like that, I took out the bios that I have tried and the bios that gives me an image but it takes seconds to give the image
              Re: X441UV Bios Problem
              Clear ME region.
                If there is a long white barcode sticker on top of the soldered ram post a picture of it
                  It seems that they do not have because I just checked on the internet and it is a label just above the soldered ram, and indeed they do not have,
                  Now I tell you a little about the process,
                  disable the soldered ram leaving it as the attached file, all ok, then I wanted to update the bios, it restarted and did not give an image but the consumption is the same as when it is giving an image, then I found the X441URK bios and it gave an image
                  I attach my bios in case it helps
                    I can see that my integrated graphics card is a 920MX while when programming the X441URK bios I get that the graphics card is a 930MX I would think that's where the fault comes from
                      try..
                      it works....thanks bro
                        Asus x441uv rev 2.1 plzz build
                        Plzz build no display i try other bios but it takes time to display tnxx..
                          Re: Asus x441uv rev 2.1 plzz build
                          Try
                            try..
                              Hi, I have asus x441uv rev 2.1, no display, fan is spinning, and battery led blink 2 times (white).
                              Specs
                              intel core i3-6006U
                              no discrete graphic
                              I would be very grateful if anyone could help.🙏
                                Specs
                                intel core i3-6006U
                                no discrete graphic
                                try..
                                  try..
                                  Hi peste, thanks for your help. Unfornatunately, It still don't work. I try your "clean me.rar" on page 1, It can boot normally and access bios menu (it's much more modern compared to my previous bios), but I have to wait about 40 seconds or more before the display comes.
                                  any ideas ?
                                    any ideas ?
                                    Try this older version.
                                    Model Number: X441UA-WX321T.
                                    Serial Number: J4N0CV00225714D.
                                    all donations are welcome,
                                      many thanks hardware1, but now it become no display, even after reflash bios with peste "clear me" on page 1. Do I need to flash the EC as well ?
                                      please help anyone
                                      My bios and EC dump
                                        please help anyone
                                        My bios and EC dump
                                        So the device was working before but now it's not?
                                        Anyway, here are your files, the EC is extracted from the Main Bios.
                                        You EC Dump file is messy, it doesn't have the correct data.
                                          Thank you so much all, especially hardware1 and peste. I managed to fix it by flashing the EC with the file I found on Google, and then reflashing the main BIOS with the latest file given by Peste. I haven't had the chance to try the file you provided yet. This is the EC bin file I used to flash the EC. Thanks anyway Hardware1. 🙏
