Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Portable, and Mobile Devices > BIOS Requests ONLY!
Old 02-15-2020, 03:15 PM   #1
e900
City & State: UK
My Country: UK
Default HP Elitebook 1030
Hello
Please help unlock bios password for HP Elitebook 1030.
I extracted soldered to mainboard and connected to ch134a usb, booted via linux mint / flashrom with disconnected battery but power to mainboard by power adapter.
I tried to -v verify but failed a few time, i extracted the bios x3 time OK and all have the same size so i think maybe ok.
Someone please confirm if the bios can be unlocked and is OK?
Thanks.
e900 is offline   Reply With Quote
Old 02-15-2020, 03:51 PM   #2
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
My Country: Bulgaria
I'm a: Hobbyist Tech
Default Re: HP Elitebook 1030
Originally Posted by e900 View Post
Hello
Thanks.
Same size =/= same content. You can compare content of the files with Total Commander or HxD. So first compare those 3 files, and if they are same will be safe to say that the dump is read OK, and you have a good backup. So before erasing the chip and programming new dump always do this or you will have a big problems.
P.S. Just checked the file - dump is bad.
Vesko356 is offline   Reply With Quote
Old 02-15-2020, 03:54 PM   #3
piernov
Moderator
City & State: Valbonne, 06
My Country: France
UEFITool has trouble reading the backup so I'd say it is bad.
In any case I never be confident working on a BIOS in a situation where verify fails.
I personally always desolder the chip and don't recommend working with a CH341A as there seems to be a lot of issues with those (and in particular related with 128Mb or more SPI ROM).
OpenBoardview http://openboardview.org | IRC #[email protected]
piernov is offline   Reply With Quote
Old 02-15-2020, 04:43 PM   #4
e900
City & State: UK
My Country: UK
Thank you, im new to this, im happy to try and learn, especially when steps and guidance is available
I also tried UEFITOOL and got some errors, but googleing them shows they maybe generic errors. Although im not sure where to start on UEFItool but did you manage to locate any password or anything about it?
I may get the chip unsoldered.
Im using the CH341a programmer, with the 3.3 adapter?
What do you recommend working with or using? Im doing this the first time for a friend.
Is there a way to flash a clean bios? start fresh? What can i do next? or do you recommend next to do?
Heres a picture of my setup
Old 02-15-2020, 05:08 PM   #5
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
This is always better rather to work with the chip in circuit.
CH341a is a 3.3V, so if your bios chip is 3.3V you don't need any adapters
Use Windows based program. Try AsProgrammer with CH341A support
DOWNLOAD LINK
Get a good bios dump first, this is a must. Than upload the file here and someone will remove the password for you. No other way, "start fresh" and so on.
That's it.
Old 02-16-2020, 04:44 AM   #6
e900
City & State: UK
My Country: UK
DOWNLOAD LINK
That's it.
Sorry I meant the 1.8v adapter? I have the 1.8v adapter also plugged in the ch341a usb...I read on a post (winraid?) that the chip may overheat if the incorrect voltage is applied to it via usb and to use the 1.8v.
How can i find out if my chip is 3.3v or if I need to use 1.8v?
Do you recommend to try direct on the CH341a direct?
I will try the windows programmer to.
Thanks again.
Old 02-16-2020, 05:06 AM   #7
e900
City & State: UK
My Country: UK
My chip is a 128 25q128jvpq + 25q64jviq
I cant find this in ASPROGRAMMER?
Flashrom in linux detects it as a "W25Q128.v" 16384 kb SPI
Old 02-16-2020, 05:25 AM   #8
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
Just power up the board and measure voltage on pin 8, and you find out. Red probe on pin 8, black probe on grond (or on pin 4).
Old 02-16-2020, 05:28 AM   #9
e900
City & State: UK
My Country: UK
Think im getting somewhere, before I begun reading the chip, the computer would not power on, the power light would blink continuously.
Since then i removed the 1.8v adapter and plugged direct to the ch341a usb programmer and the machine now powers on, fans spins. which is a good sign, better than the continuous dead feeling i had from before.
Im now trying to backup and im getting Error: file backup3.bin could not be written completely. Failed.
Old 02-16-2020, 05:35 AM   #10
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
W25Q128JV must be 3.3V but take the chip voltage with the multimeter.
If it's 3.3 than select second from the drop down menu (W25Q128FV)
Old 02-16-2020, 05:44 AM   #11
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
Read the chip first! Correctly! Take a good dump! Verify the dump!
And then try to write! And write correct dump after someone of us edit and remove the password from your backup!
Read the whole topic again. Carefully!
Old 02-16-2020, 05:56 AM   #12
e900
City & State: UK
My Country: UK
I appreciate your help and patience with this.
In Flashroom im using the -r command, (read) , im not writing anything to the bios.
I tried to read the chip with ASPRorgrammer and im getting Error connecting CH341(-1)
I have checked device manager and the ch341a is listed with no errors.
Old 02-16-2020, 06:08 AM   #13
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
To receive such an error means you didn't connect the chip to the programmer correctly.
What is used for the connection - clip, wires?
Did you measure the chip voltage?
What is the voltage measured?
Old 02-16-2020, 06:22 AM   #14
e900
City & State: UK
My Country: UK
got it! I think I was running out of free space on the disk / usb, im using live CD mint.
Attached the bios. I tested opening the bios is uefi tool and it looks good, no errors compared to the ealirer one i posted.
Please let me know?
Old 02-16-2020, 06:33 AM   #15
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
Please let me know?
Take the dump once again so I can compare both files.
I receive an error reading the dump file with ME Analyzer, which means the dump is not OK
Code:
Error: Detected CSE Extension 0x03 with wrong Partition Hash at FTPR > FTPR.man!
Take the dump with AS Programmer also.
Old 02-16-2020, 06:41 AM   #16
SMDFlea
Moderator
City & State: York
My Country: UK
Remove the pass and clean the ME ,it should be ok .
SMDFlea is online now   Reply With Quote
Old 02-16-2020, 06:52 AM   #17
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
Let's wait to have a second file to compare, password and ME region are easy, the important thing is to make sure the bios file is read correctly. I'm just not sure what he's doing there.
Old 02-16-2020, 06:54 AM   #18
e900
City & State: UK
My Country: UK
Thanks guys,
Running ASProgrammer now, just reading at the min
Old 02-16-2020, 07:01 AM   #19
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
Thanks guys,
Ok great, take your time don't hurry.
Old 02-16-2020, 07:06 AM   #20
e900
City & State: UK
My Country: UK
all done, did a verify with ASProgrammer and all ok (no errors)
Took x2 dumps, both on ASProgrammer.
