Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Portable, and Mobile Devices > BIOS Requests ONLY!
Thread Tools Display Modes
Old 02-16-2020, 07:12 AM   #21
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
My Country: Bulgaria
I'm a: Hobbyist Tech
Default Re: HP Elitebook 1030
Quote:
Originally Posted by e900 View Post
all done, did a verify with ASProgrammer and all ok (no errors)
Took x2 dumps, both on ASProgrammer.
Excellent! Good job, now just wait to compare all files, and if it's the same will proceed with the unlock. So be patient.
P.S. All files have the same content - good job.
__________________
Vesko356 is offline   Reply With Quote
Old 02-16-2020, 07:24 AM   #22
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
Now erase the chip, write this file, verify the written file and power up the machine. If everything is ok reply here, if not will prepare new file to try with.
Old 02-16-2020, 07:50 AM   #23
e900
City & State: UK
My Country: UK
I'm a: Knowledge Seeker
Just running a verify.
Once OK, is the system able to boot with the usb connected as im soldered to the board?
e900 is offline   Reply With Quote
Old 02-16-2020, 08:00 AM   #24
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
Yes but disconnect the wires from the programmer side. Just leave the wires as is soldered to the chip (make sure they are not tuching anything or each other!). Just raise the lever and remove the connector from the programmer.
Old 02-16-2020, 08:01 AM   #25
e900
City & State: UK
My Country: UK
Ok, switched on, no display, power light on, keyboard flashes, and fan start spinning.
I have the hdd attched, Wifi adapter plugged in,
Programmer disconnected
Old 02-16-2020, 08:07 AM   #26
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
OK, hold on. Will prepare second file to try with.
Old 02-16-2020, 08:17 AM   #27
e900
City & State: UK
My Country: UK
sure will do, im just placing the board back in the case, mount the screws and plug the cables in...is that ok? or should i leave it disconnected ?
Old 02-16-2020, 08:41 AM   #28
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
It's OK, just disconnect charger and battery if you playing with the screen connector!
Try it and feedback to me:
Old 02-16-2020, 09:28 AM   #29
e900
City & State: UK
My Country: UK
YESSSSSSSSSSSSSSSSSSSS IM in, i can see the see just doing the system time
Old 02-16-2020, 09:36 AM   #30
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
So we are back in business - pretty cool, huh?
Old 02-16-2020, 09:38 AM   #31
e900
City & State: UK
My Country: UK
yes password is clear, can access the bios THANK YOU!!
Really appreciate it.
Im just running through the settings will close it up and put the battery back in.
Im finding the computer a while to goto the HP / splash screen?
Old 02-16-2020, 09:39 AM   #32
e900
City & State: UK
My Country: UK
Quote:
Amazing work,
How can one learn about bios modifications?
Old 02-16-2020, 09:54 AM   #33
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
Amazing work,
Congratulations!!! I'm very glad we did the job, and I'm just imagine how pleased you are with the result. It's like magic, right? Enjoy the result of a job well done. Have fun!
Old 02-16-2020, 05:19 PM   #34
e900
City & State: UK
My Country: UK
I want to cry..and say sorry.
So tonight i closed the laptop up, tested it all earlier working great, set time date and settings and its save it, and then...........
begun removing the wires.....with a cutter ( i managed to snip close to the contact) and twisting the wire and arghhhhhh
I wish i didnt and now it wont power on, just power light on.
On inspecting the chip area it looks like the gold contact pad on pin 2 is missing.
The rest of the pins look OK as the solder is intact minus the wire, just pin2 (the one below pin 1) is no solder and no gold contact.
Could I have damanged the chip and or will this be repairable with just a new pad / gold pad? I have a magnifying glass and im pretty sure I can see the solder contact on pin 2 but no gold pad on the board.
I did disconnect the battery and have no power to the laptop.
I know have to wait for a week to get the board checked, as the guy who soldered for me is on holidays.
I feel so so bad after the hard work by you. Truley gutted and i hope it can be fixed without a new chip.
Old 02-17-2020, 03:38 AM   #35
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
I just can't believe... after a half day work...
A cutter? You must be joking. Why?
No, it's not the chip, most probably you ripped off the pad, and now the signal is missing from this pin to the board.
Take a good quality photo of the damaged area, most probably the path from that pin to the board can be restored with a wire, but let's see. And don't touch the cutter anymore.
Old 02-20-2020, 07:03 PM   #36
e900
City & State: UK
My Country: UK
i know.
Pictures attached, the first ? x4 of the pics are through a magnifying glass (looks worse then it is........hopefully it isnt)
Looking at the pics, i can see solder on the pin 2 so i think it maybe pin 4?
Let me know what you think.
Old 02-21-2020, 03:08 AM   #37
Vesko356
Sharpshooter
Vesko356's Avatar
City & State: Sofia
i know.
it turned out to be exactly what I thought - pad on pin 2 is ripped off, it looks pretty bad, but it's fixable. But it's advisable to be done by someone who has experience in soldering. See the picture:
Old 02-21-2020, 03:58 PM   #38
e900
City & State: UK
My Country: UK
Wow, amazing point out. I didnt notice the track im just looking below the chip to see where it connects to.
I will have to wait till next week for the guy to be available.
Will post back with update.
Old 02-29-2020, 12:59 PM   #39
e900
City & State: UK
My Country: UK
Update - we chacked under x25 microscope and the chip is damaged, "the anchors" are missing.
So means new chip time.
Do I have to get the same one? I guess i can pick one from ebay?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
