Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting & Designing Networks
Thread Tools Display Modes
Old 02-21-2020, 02:32 PM   #1
nosugartonight
City & State: Bluefield Virginia
My Country: united states
I'm a: Knowledge Seeker
Default Wifi signal
Hay. Not sure if This post is in the right place but here it is. My neighbor said I can use his wifi. The signal is weak. I assume it's because of the distance. Approximately 150 feet. Also there are other open wifi but are weak also. Is it possible to extend the antenna wire out of the tv to the outside to a antenna to improve signal strength.
nosugartonight is offline   Reply With Quote
Old 02-21-2020, 03:00 PM   #2
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Default Re: Wifi signal
get yourself a ubiquiti oudoor AP or similar.
CapLeaker is offline   Reply With Quote
Old 02-21-2020, 04:34 PM   #3
nosugartonight
Not looking for gadgets was just wanting to know if its possible. All smart TVs I've been into. Only have a small piece of metal at the end of antenna wire. So could that wire be extended to the outside, maybe connected to an Ariel antenna or simply to so aluminum foil to pick up better. any thoughts will be appreciated.
Old 02-21-2020, 06:15 PM   #4
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
no, the losses in the cable will remove anything you gain from a decent 8dB+ antenna
stj is offline   Reply With Quote
Old 02-21-2020, 06:35 PM   #5
petehall347
City & State: worcester
My Country: United Kingdom
antennas on the router might help
petehall347 is offline   Reply With Quote
Old 02-21-2020, 07:36 PM   #6
nosugartonight
Ok. I have routers .Not on his network.
Old 02-22-2020, 07:28 AM   #7
stj
stj's Avatar
maybe you can use a router in reverse to link to his router.
some have that option, others can sometimes have better software installed.
what routers do you have?
Old Yesterday, 02:19 PM   #8
madan1
City & State: Sofia
My Country: Bulgaria
Get a cheap tp-link 740, install dd-wrt and connect it to the other wifi network as a client. After that you can use cable to connect your TV ( and other devices ) to that router or add a virtual wireless network to which to connect your devices.
madan1 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
