Hello everyone.
i have psu with dead 5vsb voltage. Xigmatek tauro 400w, 5vsb use STR-A6069H.
First guess, dead IC. So i order new one and replace it.
But no success. Still no 5vsb output.
I've checked all diode, replace the small capacitor, test the resistor around the ic, but not found any error component.
Further inspection, i found vcc input of A6069H is bouncing between 8v to 13v. which is based on datasheet need typical 15.3v to start.
I guess, maybe unstable voltage of A6069H VCC, paralysed 5vsb.
What can cause the unstable vcc voltage ?
Because i already checked all components in primary side, can some faulty component in secondary make this problem?
Thanks alot.
Thanks alot.
