Vcore = 1.37 V on CPU ? FET issue ?
    Guys,
    I got 1.37V on Vcore, normally I got around 1.25V
    And the board is shut off after few seconds...
    Does it matter of 1.37 V on Vcore CPU ? or already over voltage ( FET problem )
    Re: Vcore = 1.37 V on CPU ? FET issue ?
    What CPU is this for?
      It's Core 2 Duo E6550....still acceptable isn't it?
        Stock voltage for the E6xxx Core 2 Duo CPUs is 1.35V, I believe... so 1.37V is fine. The reason you may see a lower voltage on a working motherboard is because of Intel SpeedStep, which reduces the core clock and CPU voltage when system is idle.
